Old 31st October 2005, 12:10 PM   #1
Wynand is offline Wynand  South Africa
Wynand's Avatar
Default LM3876 for guitar?
Would I be able to use the LM3876 chip for a guitar amp?
If so would I be able to use the schematic in the datasheet, or would I need a buffer/preamp stage with or without gain.
I've tried to look around and couldn't find something to use.
If someone's got a relatively simple design I would love to see it.
Old 31st October 2005, 04:27 PM   #2
matjans is offline matjans  Netherlands
matjans's Avatar
Send a message via MSN to matjans
hi,
i'd use an opamp in front of a standard lm3875 based amp (if that's what you're thinking of).
take any standard opamp, give it a high input impedance, say ~500kohm, and some gain. schematics are everywhere
Si fractum non sit, noli id reficere!
Old 31st October 2005, 04:40 PM   #3
Nordic is offline Nordic  South Africa
Nordic's Avatar
Hey Wynand, is lekker innie kaap vandag!!!!!!!!!
What speaker do you have?
I must say the basic inverted config is probably easier to put to together than the noninverted setup from the datasheet. Especialy with the mono 3875 version.
Old 2nd November 2005, 05:26 AM   #4
sagarverma's Avatar
wynand
better use tda7294.they have better mid and up freq response.
lm series has good low freq response.it heavy on bass.
Old 2nd November 2005, 08:26 AM   #5
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
Marshall is using the TDA7293 as power stage in various combos.
They are ok. Use a decent heatsink!!!
Zilog
LM3876 and 4-ohm drivers astrodog Chip Amps 15 2nd July 2008 11:22 PM
LM3876 for small sub amp? phreeky82 Chip Amps 11 5th July 2006 05:50 PM
LM3876 vs. LM3875 Wynand Chip Amps 3 12th July 2005 09:03 PM
Help with a LM3876 amp! (nOOb) Fizx Chip Amps 3 24th June 2005 07:22 PM
Lm3876 bobossa Chip Amps 1 1st March 2005 04:18 PM
Page generated in 0.15700 seconds (42.45% PHP - 57.55% MySQL) with 10 queries
