| Chip Amps Amplifiers based on integrated circuits |
http://www.redcircuits.com/Page60.htm
anyone tried this preamp???is it really high quality?? plz tell me how it works suggest improvements is tl072 fine?? how to alter its gain?its at 4 and want to get it to 2. there is another preamp using discrete components on http://www.redcircuits.com is it really high quality????? which one should i go for? i/p from sony discman. thanks in advance |
#2 |
Hi there,
"High quality" is relative. But in the audiophile term, such pre is not hi-end at all. Anyone hang around this site for more than a year won't build such preamp IMO. Try this site: http://sound.westhost.com (or search by that words) you will find very valuable projects as well as information/theories. There is a project for preamp, along with useful information to answer your question. Rod Elliot's products quality is above average IMHO. Or may be you want to try Nelson Pass' Bride Of Zen (BOZ/BOSOZ). They are my favourite SS preamp so far. |
#3 |
thanks for reply
i want to build a preamp with perfect faithful gain of two so the quality is not sacrificed.r the distortion figures mentioned for it sufficent for good quality. i know bout Mr Elliot's site.but he uses too many components that make pcb cad painful(it took a month for 12b xover lr) boz sounds interesting. i have made pcb for the pamp in ques,(bec reply came in too late from anyone) will post results soon. |
#4 |
I am no expert on what makes an ideal preamp, but I do know the TL072 is a very very cheap op-amp. To make the circuit better use a high quality op-amp, and make sure that C4 and C5 are high quality caps(polypropelyne, polyester, etc.). I am also curious on why it had been designed to use a single supply. IMO a preamp designed to use a + and - supply would be a better choice.
A design I think you should look at is Russ White's FreeBird. It is very simple and very effective. It uses expensive op-amps but I'm sure they can be exchanged with something else if you are on a budget.
The power of Science compels you! |
#5 | |
#6 |
well i have constructed this pamp.
****tl072 is a nice chip,good figures for the price**** its working good but has hmmmmm prob.maybe bec of caps u advising to change.will replace by philips ones. strangely its working!!i never expexted it to work given single pwr supply.performance is good but far from what i want. looking at rod's pamp.anyone done it.advise plz. |
#7 | |
#8 |
done rods car preamp with ae
very good performance.works great. my music i/p is from sony discman.a very peculiar thing happens at high volume,the bass dissappears at high volume from the discmans o/p advise req on how to have a low freq gain so bass is high throughout the spectrum. can the preamp b modified such that low freq has gain?preamp in this case is esp's car preamp with ae. or do i need some other ckt.plz advise on requisite ckt. |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 10:13 PM |
| Page generated in 0.11376 seconds (75.78% PHP - 24.22% MySQL) with 10 queries |
