Lm4702 - Page 49 - diyAudio
Old 3rd November 2012, 03:47 PM   #481
ingo50 is offline ingo50  Germany
to rambojj
those chips do different jobs: LM 4702 has the diff.input and the VAS without the currant-gain outpt-stage but has two chanels , whilst the LM 3875 contains a complete midpower opamp
see also: www.ti..... You can not compare apples with pears as we say in german
ingo
Old 21st December 2013, 12:22 PM   #482
bra is offline bra
Here is Arcam's way - maybe the best way :-)
Old 21st December 2013, 12:29 PM   #483
bra is offline bra
and power stage - they use the same in new AVR750 so it have to be very good amplifier - I want use the voltage stage in my Primare SPA20
Old 21st December 2013, 05:19 PM   #484
jackinnj's Avatar
The best way is to buffer the input, invert, and feed the inverting input of the LM4702. I used the OPA2604 -- it really sounds nice. I had some boards made up for a LM4702 project which was published in AudioXpress and found that I could fit the OPA2604 and associated components in the space of the rather large capacitor I was using.
Old 28th December 2013, 01:07 PM   #485
microx is offline microx  Spain
Default suitable mosfets
I have two pairs of Exicon 10P16/10N16 lateral mosfets I would like to use with a LM4702. I plan a 2K preset across the gates for bias adj and 220R gate stoppers. Anything else I should bear in mind.
Old 6th January 2014, 09:59 AM   #486
bra is offline bra
i have done, now my primare has lm4702 with original power emiter follower and it sounds great with my Dali Grand, i am very happy with it.
sound i precise, dynamic with wide and deep soundstage.
lm4702 is a high end chip in my opinion.
Old 24th January 2014, 07:58 PM   #487
jackinnj's Avatar
Use a 1k potentiometer between the SINK and SOURCE outputs of the LM4702so that you can set the bias, AND a 47k resistor from SINK to ground. Bias for about 120mA.
Old 15th February 2015, 11:46 PM   #488
terranigma's Avatar
I'm going to build a kit based on schematic below. I couldn't figure out the function of R3(180 ohms) in the schematic between emitters of driver transistors. Should I avoid it?
Thanks.
Old 16th February 2015, 01:53 AM   #489
The simpler the better. Have been using this circuit for over 5 years and sounds outrageous. I use two 4702s....one for for each channel and ground the unused inputs on the other unused channel. Dual mono is always better. I use a single power transformer for each channel but rectify it twice so I have a separate power supply for the 4702 and for the output mosfet stage....very important for great sound. I use nude Vishay resistors, damped heatsinks, damped soft recovery diodes, binding post bypass system, nude Blackgate N in feedback with nude modded Wima bypass and modified Wima Bypasses on all power supplies. You do not need the zobel network or inductor on the output if you are driving non capacitive normal speakers. Driving electrostats will require a zobel and maybe the inductor.
Old 16th February 2015, 01:57 AM   #490
How do you attach a picture as a thumbnail?
Lm4702 Mike Gergen Chip Amps 109 31st August 2008 01:30 AM
Lm4702 Bpa halo0925 Chip Amps 19 13th November 2006 04:47 AM
Lm4702 BPA halo0925 Solid State 0 9th November 2006 10:26 PM
Copyright 1999-2017 diyAudio
