Lm4702
Lm4702
Old 25th October 2005, 12:08 AM   #11
Easyamp is offline Easyamp
Easyamp's Avatar
Very exciting, I can't wait to get my sample's. I've moved away from chip amps but these seem worth the time.
Old 25th October 2005, 12:29 AM   #12
aletheian is offline aletheian  United States
aletheian's Avatar
Has anyone done any "back of an envelope" math on current consumption and voltage requirements on one of these?
Heghlu'meH QaQ jajvam!
Old 25th October 2005, 02:53 AM   #13
tiltedhalo is offline tiltedhalo  United States
Default LM4702
This is the same package as the 3875,76,86 ect..... is a power darlington complimentary output pair with much higher power handling up to +- 70V to as high as 100 +- dissipation is still only 125W quiescent current is 30 ma distortion is .004 at 14RMS out, it actually is not as good overall as its conterparts just handles higher power supply voltages................
Old 25th October 2005, 07:12 AM   #14
UrSv is online now UrSv  Sweden
UrSv's Avatar
Default Re: LM4702
Originally posted by MikeLewis
From the Spec Sheet:
POWER DISSIPATION AND HEAT SINKING
When in “play” mode, the LM4702 draws a constant amount
of current, regardless of the input signal amplitude. Consequently,
the power dissipation is constant for a given supply
voltage and can be computed with the equation PDMAX = Icc
* (Vcc – Vee). For a quick calculation of PDMAX, approximate
the current to be 25mA and multiply it by the total supply
voltage (the current varies slightly from this value over the
operating range).
Constant power draw? This sounds like it's going to be a real hog. Is this Class A?
Guys do the maths...
Sure it's Class A, but it's a DRIVER not a power amplifier. To build a complete amplifier you need to add external components for the output stage and that's where the big power disspation will be. The current for the driver IC is 25 mA and the current available model in production is the A grade which means maximum +/- 75 VDC supply. This gives Pmax=(75-(-75))*0.025 W = 3.75 W of dissipation. Yes, that's less than 4 W. No need to worry...
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 25th October 2005, 03:38 PM   #15
youyoung21147 is offline youyoung21147  France
Send a message via MSN to youyoung21147
Nice thing !
The point is to find the suitable power follower for this awesome chip, and have the money for the heatsink invloved
Gainclones may still remain the most popular chip amps
Old 25th October 2005, 10:34 PM   #16
metal is offline metal  Jordan
metal's Avatar
Hi
Cool stuff in deed for the power hunger guys...
Who can recommend the power output transistors to be used with this chip LM4702...
Old 27th October 2005, 07:44 PM   #17
elementx is offline elementx  United States
elementx's Avatar
MJ11032 from Onsemit should work fine, samples are available. I know I've had a sample request on the 4702 for over a month... it's on backorder... anyone actually play with them yet?
Originally posted by pinkmouse
That does look very interesting.
However, this looks much more fun!
I agree! I actually got that chip, but it is surface mount and incredible small! I can't handle soldering it... anyone else upto the challenge?? I'd be willing to work out some sort of trade/purchase if you could just glue the thing to a piece of cardboard and solder some leads on it!
Old 27th October 2005, 08:23 PM   #18
wes-ninja250 is offline wes-ninja250  Canada
wes-ninja250's Avatar
ElementX -- can you make a PCB good enough for it?
You can use solder paste and a toaster oven to actually solder it on. If that's the only component on the board, I expect you would get it right after only a few tries.
http://www.seattlerobotics.org/encod...6/oven_art.htm
Wes
Do daemons dream of electric sleep()?
Old 27th October 2005, 08:40 PM   #19
demogorgon is offline demogorgon  Norway
demogorgon's Avatar
Send a message via MSN to demogorgon
***** ********* ******, this is awsome..
I have got to get myself some o'these..
how's nationals sample program these days? just as tight as before i presume?
Old 27th October 2005, 09:15 PM   #20
RCBandwidth is offline RCBandwidth  United States
RCBandwidth's Avatar
Default Funlight
For ElementX: I have successfully soldered the LM4970 device and
tried it out with a picmicro,it's an interesting device if you are interested in adding some "Bling" to your next project...
BTW: I have a stereo microscope that I used while soldering....Those little buggers look like 18 wheelers under the scope!!
Regards Bob C.
Lm4702Hide this!Advertise here!
Lm4702 Mike Gergen Chip Amps 124 19th February 2018 01:47 PM
Lm4702 Bpa halo0925 Chip Amps 19 13th November 2006 04:47 AM
Lm4702 BPA halo0925 Solid State 0 9th November 2006 10:26 PM
