| Chip Amps Amplifiers based on integrated circuits |
Ok, so Brian and I have been talking about a source and amp selector for quite a while. Finally it is coming to into existance... even if slowly.
![]() The layout is nearly complete, but still has some tweaking. I know many of you guys have been asking me about this for quite a while, and I though it was about time to show some work. Here are some details: 1) 3 stereo sources. 2) A selectable output buffer. 3) 2 outputs which can operate independantly or together, but from the same input source. 4) PIC MCU controlled with headers which allow for various input devices (switches, Qprox..., etc...) 5) On board PS for easy layout and integration with other projects. The idea is for this to a be a companion to the Kookaburra preamp and Mauro's "My Ref" amp. Keep in mind this is a work in progress... Stay tuned!! ![]() Well here it is:
Less pulp more juice Twisted Pear Audio. |
#2 |
You should consider moving the in/out pinheaders closer to the relays so that the "ground"-pin has a better connection to the ground plane
![]() /U. EDIT: Nice job, again, of course
#3 |
Thx Nisbeth,
Here is a new PIC which is a lot easier to read, and has your change.
#4 |
Much better
/U. |
#5 |
I added one more change,
I added JAC1, JAC2, and JGND which are simple 0R resistor jumpers which allow you to use one trafo or two for semi-isolated or fully isolated PSs. Though I am pretty sure JGND should always be in place.
#6 |
looks good! btw what is the size of the board so far?
"I Love To Camp!" "Comensing Shock Therapy!" |
#7 |
Thanks!
Well, its about 4.2" x 3.2" and it won't get any bigger, it may get a little smaller. Cheers! Russ
#8 |
...truth seeker...
Hi Russ,
Will there be an option to use off-board PS?
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#9 |
It would be easy enough to do with the PCB, but honestly probably no big gain there.
You would simply omit PS parts up to the REGs and wire your PS to the REG GND and OUT pads.
#10 |
Actually I meant including the regs. You would omit them as well.
| Input selector | Simo88 | Everything Else | 25 | 15th July 2009 01:33 AM |
| input selector | lawbadman | Digital Source | 8 | 10th September 2005 09:45 AM |
| Input-output selector | reticent67 | Digital Source | 3 | 15th May 2004 04:02 AM |
| input/output source selector | luurmees | Parts | 1 | 4th May 2003 09:20 PM |
| Input selector: need help | Cobra2 | Parts | 1 | 8th March 2003 07:31 AM |
| Page generated in 0.17826 seconds (52.09% PHP - 47.91% MySQL) with 11 queries |
