| Chip Amps Amplifiers based on integrated circuits |
I built a Audisector gaiclone a while ago and am very pleased, however I have always been abit worried about plugging things in for the first time and about whether they output DC.
I know you can use capacitors to block DC but I am not sure which type to use, can you use any type availble? because I have some 1500uf and some 10uf electrolytic panasonic ones left (polarised) which I want to use or, would I have to buy a special type? e.g. non polarised or not electrolytic and if you can use polarised which way do you put them. Also I know they may effect the sound. Thanks Very Much, |
#2 |
just another
Hi Dome,
You could probably connect up two of the 10uF electros back to back (ie in series with either +ve to +ve or -ve to -ve). that will give you around 5uf. This is a bit bigger than I have seen generally used but shouldn't be a problem. Ideally you should use something like a 2.2uF polypropylene cap. This is non-polarised, but has the disadvantage of being physically bigger and much more expensive ![]() Tony. |
#3 |
Thanks for the fast reply, I will probably get some polpropylene. components keep getting harder to get and more expensive in the uk
which is a shame.Is there a difference between audio grade and normal? |
#4 |
just another
apart from price???
I've only used generic brand polypropylene crossover caps personally, so I can't comment on whether I think there is a difference, between audio grade and standard polyprops. I will say that I thought that they were an improvement over the bipolar electrolitics that they replaced though ![]() Tony. |
#5 | |
As you probably know, in audio, when you get to a certain quality stage you also enter the law of diminishing returns for any new improvement. There was an article in Audio Electronics some time ago where they tested several polypropylene caps, from cheap to very expensive, and differences (if any) seemed to be very, very small. One thing that is important, though, is what type of wire are the terminals made of. If they are non-magnetic then I don't think there will be much of a difference between the caps. Carlos |
#6 | |
If you have Panasonic FC 10u left, use those for coupling. Don't use them back to back, just a single cap. If you'll pleased with the sound, leave it like that. Otherwise, I would suggest BG N 4.7u, which IMO are better for coupling than most pricey exotic brands. They are also cheap, at $3.25/pc.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#7 |
Why not use polyester (mylar) caps? They're also non-polar as the polypropylene, cheaper and quality wise, they (theoretically) should be between polypropylene and aluminium electrolytics.
In case you really decide for polypropylene, the cheapest I've seen are here: www.reichelt.de, search for "vis folie" they seem to be come from Visaton (though I don't know if they just buy them from someone else) Cheers, Dominique |
#8 |
just another
polyester is a good low cost option, I'd say definitely better than cheap electros, though Peter feels that the BP black gates are better than even the polys, and at the price I'd say they are a bargain... (if unlike me you can source them locally).
I just realised that my input caps I repaced with polyproylene weren't electros, they were polyester green caps, and I did notice an improvement. don't think it was psycoacoustic but you never know ![]() Tony. |
#9 |
Thanks for the help, I am going to try them panasonic caps today (as it is half term) and test out a volume control out of spare parts from an old stereo before i buy some new parts.
#10 |
Sory to revive an old thread, but my question falls right in line with this topic.
I also built an Audiosector kit, but its a LM4780 in stereo configuration. All parts are stock and per the kit. Recent modifications to my PS1 lead me to trust it a little less, until it proves it self. Also I like switching between iPODs and have noticed some sound quality differences between models. I have read on here that many suggest putting a small cap across NFB resistor. I believe on the AS LM4780 that is R5 and R6. What values should I start with? 1uF? Also many suggest placing capacitors across the input resistors (R0 and R4), would 1uF also be a good starting point? I also see 2.2uF thrown around. |
| DC Blocking on Pre-Amp | Puffin | Chip Amps | 8 | 22nd January 2009 08:08 PM |
| DC Blocking | fdeck | Digital Line Level | 5 | 12th November 2008 03:55 PM |
| Favorite film capacitors for DC blocking? | The Peasant | Parts | 18 | 1st December 2006 04:37 PM |
| DC blocking capacitors | soundNERD | Chip Amps | 4 | 25th October 2005 01:36 AM |
| BZLS (aka, BoSoZ?) Blocking Capacitors...what am I missing??? | NV&H | Pass Labs | 7 | 5th February 2005 08:03 PM |
| Page generated in 0.13377 seconds (77.69% PHP - 22.31% MySQL) with 10 queries |
