how the best chip amp for 12V ?
Old 22nd October 2005, 03:13 AM   #1
dito is offline dito  Brazil
Send a message via MSN to dito
Post how the best chip amp for 12V ?
Hi firends, i would like to know, what is the best chip amp for design a car amp in your opinion? If possible, say why...
Old 22nd October 2005, 06:01 PM   #2
Tweeker is offline Tweeker  United States
A bridged class D amps like the Tripath gets my vote for simple projects, first chips that come to my mind for a 12V supply. If you need more power your either looking at paralleling and using low impedance speakers, or comming up with a higher voltage supply.
Old 22nd October 2005, 07:10 PM   #3
JZatopa is offline JZatopa  United States
remember that a car, when running, is 13.7V if that makes a difference.
Old 27th October 2005, 05:22 PM   #4
sagarverma is offline sagarverma  India
sagarverma's Avatar
Default your search ends here.tried and tested(one full year of rough and tough service)
use tda1554q,tda8563
great ones both.44w and 80w resp.both run directly off car battery.latter 2 ohm stable.both giving active service in my car.great performers.highly reliable(perform well whatever be car temperature).check datasheets.highly recomended.
Old 27th October 2005, 05:27 PM   #5
sagarverma's Avatar
Default oops forgot
very very low component count req for both.(i suppose 2 or 3 caps,1 or 2 res).small pcb(2'' * 1.5'').quality is excellent.i using them very roughly for close to a year still they workin.can be driven directly off cdmans etc etc.very cheap.even the final prod is cheap.even installation is cheap.
highly recommended
Old 29th October 2005, 02:22 AM   #6
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
try chips from Philips or ST,they are quite good.
how the best chip amp for 12V ?Hide this!Advertise here!
Which Chip AMP you like most? dynabok Chip Amps 154 12th December 2012 01:23 PM
Pre-amp for chip amp wotsascott Chip Amps 23 30th April 2006 04:24 PM
First Chip Amp doomsweek Chip Amps 9 10th May 2005 01:55 AM
Best possible 10W from chip amp Robert_66 Chip Amps 14 2nd November 2004 11:43 AM
Hot chip! batkey Chip Amps 1 14th October 2004 11:54 AM
Copyright ©1999-2017 diyAudio
