| Chip Amps Amplifiers based on integrated circuits |
I built a Brian Kit lm4780, parallel mode, and am in the process of modifying the grounds and adding some capacitance to the PS recitfier (4x8200/ch). I ran into some ground noise between the two channels and, so I am running one ground wire from the PSs to the amp boards, instead of the 4 per 2 amp boards. I have the chance now to use a different return location for the speaker load (maybe at the single point just before the amp board or at the single point at the PS), instead of the amp board. My inclination is to return it the single point of the PS, closer to the large caps. Any thoughts? Thanks for any inputs.
-BG |
| Power load, dummy load (pic) | luka | Power Supplies | 43 | 9th February 2012 02:50 PM |
| Dynamic load line analysis using music and speaker load | Michael Koster | Tubes / Valves | 0 | 7th March 2008 08:47 PM |
| SI T-Amp 2 ohm load | edjosh23 | Class D | 2 | 21st February 2007 04:54 AM |
| The best load of gc | digi01 | Chip Amps | 1 | 5th April 2004 07:18 AM |
| Zen.4 in a 4 Ohm Load? | Rino odorico | Pass Labs | 8 | 18th September 2002 02:04 PM |
| Page generated in 0.05805 seconds (68.07% PHP - 31.93% MySQL) with 10 queries |
