Old 13th October 2005, 08:38 AM   #1
Talking Choosing the right potensio's value??50k/100k/1M?
Hi, i'm confusing about choose the right potensio's value. Usually people using 50k pot (assumed they don't use a preamp). In a basic theory, max value of the input's pot will give the best result, there is no drop voltage.It's necessary to keep our GC to have HI-Z in.
But, why GC'ers using 50k/20k as an input pot?Why they don't use a higher value like 100k/1M?
Using a lower value will causing drop voltage?is it right?
Need ur opinion please
Old 13th October 2005, 09:00 AM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
If I read the datasheet correctly Rin is supposed to be between 10k and 100k.....
Old 13th October 2005, 10:18 AM   #3
Send a message via Skype™ to slackman
Usuaslly potis with higher values tend to produce more noise than low-value pots...
Michael
Old 13th October 2005, 12:07 PM   #4
PierreG is offline PierreG  Canada
PierreG's Avatar
What datasheet are you talking about?
Old 13th October 2005, 03:26 PM   #5
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
I would think the LM3875 datasheet.
"A squid eating dough in a polyethylene bag is fast and bulbous, got me?"
Old 13th October 2005, 03:55 PM   #6
Nordic's Avatar
Correction it is Rf1 wich is recommended to be between 10 and 100k... lthough it does warn against big values for RIN
...page14
"The desired input impedance is set by RIN. Very high values
can cause board layout problems and DC offsets at the
output. The value for the feedback resistance, Rf1, should be
chosen to be a relatively large value (10 kŮ–100 kŮ), and
the other feedback resistance, Ri, is calculated using standard
op amp configuration gain equations."
Old 14th October 2005, 03:04 AM   #7
So,do you agree if we using 1M pot?not using 50k pot?As far as i know, high Zin is important to keep the voltage to the chipamp from the source. Ussually after pot, we add a resistor (22k) to ground, why we don't use 1M to keep in High Zin?
=>$100k Amplifiers !!! Bonsai Solid State 19 29th November 2008 03:39 PM
EL-34 and 100k pot podboy Tubes / Valves 1 26th June 2007 11:49 PM
Aleph 2 - 100k mfd enough? TwangBar Pass Labs 7 14th November 2006 01:17 AM
50K vs 100K POT ss1 Parts 7 22nd July 2004 12:57 PM
50K or 100K pot? 2Bak Chip Amps 14 9th November 2003 02:25 AM
Page generated in 0.09426 seconds (75.50% PHP - 24.50% MySQL) with 10 queries
