| Chip Amps Amplifiers based on integrated circuits |
I just built a USB DAC based on the PCM2902 + TPA6120A2 for driving my 32 ohm headphones, between the output of the pcm2902 and the input of the TPA6120 I put a OPA2134 with a gain of 3, the sound is great, but here is my question: I hear the same (volume and quality) at the output of the TPA6120 and at the output of the OPA2134, so the OPA2134 is working like a Cmoy headphone amp, and now I don't what's the difference between the Cmoy and the TPA6120A2?????
attached are the eagle files of the DAC+AMP, I now the pcb is awful, but it works! |
#2 |
if you really want to report the huge differences between amps you see here and on diyaudio you really shouldn't have 2 amps side by side where you can compare them quickly and at the same volume - you need some time to forget the fine details of the sound and some work with the soldering iron to contemplate and build your expectation of the mod's effect
the 2134 shouldn't be too bad up to ~15 mW into 32 Ohm headphones, +12 dB pwr added to high 98 db/mW headphone sensitivity (most grado's) gives 110 dB spl before clipping/distortion - that's loud the 6120 is probably limited by voltage swing w +/- 5 V supplies to ~ 3 V peak amplitude vs the ~1 V peak the 2134 can manage before current limiting - so the 6120 can manage ~ 10x the peak pwr vs the 2134 or 120 dB spl - that's really loud since 110 dB spl is unsafe listening level for any length of time the difference should only show on very high dynamic range recordings of high dynamic instruments - no cd that is ever played on the radio will qualify |
#3 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#4 | |
#5 |
nabetse' cirucit diagram shows +/-5 V supplies
| TPA6120 as a preamp.. | Dxvideo | Chip Amps | 4 | 4th September 2008 12:13 PM |
| TPA6120 Question | Dxvideo | Chip Amps | 6 | 4th March 2008 08:14 AM |
| parallel TPA6120? | bob_v5 | Chip Amps | 31 | 30th October 2007 09:36 AM |
| Reference Headphone Amp: TPA6120 | zagisrule! | Headphone Systems | 9 | 21st February 2007 05:09 PM |
