| Chip Amps Amplifiers based on integrated circuits |
I use my IGC with a Bottlehead Foreplay pre-amp, which has a 2uF output cap. I recently upgraded the output caps in the Foreplay, so it seems like a good idea to bypass the IGC input caps, as they seem to be redundant.
Am I missing something here? Also, in the IGC there is a 22K resistor to ground between the input and the cap, I assume I should get rid of that as well? |
#2 |
Measure the output offset without the cap.
If all is within specs you can leave it out. Not so for the 22k. /Hugo
#3 | |
What is the purpose of the 22K? (Just to make certain, R4 in the following schematic: http://www.platenspeler.com/diy/amps...5_inverted.gif.) |
#4 |
R4 determines the input impedance of the circuit.
/Hugo |
#5 | |
#6 |
R4 in parallel with R1 determines input impedance. R4 provides DC bypass.
#7 |
I think the input caps can be remove like nigc.I have try it with my inv3886 pcb.it works fine.
dc offset is a issue,add a 220K trim at active terminal to ground is helpful. Zang |
| Bypassing B+ in PP amp | oshifis | Tubes / Valves | 6 | 5th May 2008 08:28 PM |
| Bypassing | Lostcause | Parts | 8 | 23rd August 2006 07:24 AM |
| Dyna ST70 experience bypassing input tubes | tubesmuggler | Tubes / Valves | 12 | 20th August 2006 05:54 AM |
| Why bypassing this way? | StefanJ83 | Parts | 4 | 30th January 2002 10:38 PM |
| PS bypassing in BOZ | pjkunz | Pass Labs | 1 | 17th November 2001 12:40 PM |
| Page generated in 0.10964 seconds (68.81% PHP - 31.19% MySQL) with 10 queries |
