Cheap 24v SMPS - advice needed
Old 6th October 2005, 07:01 PM   #1
ericallan is offline ericallan  United Kingdom
ericallan's Avatar
Default Cheap 24v SMPS - advice needed
Nuuk may be able to help here - I've found some 24v positive SMPSs for about 10 each. May be able to get some more if there's any interest. I've tested the output earth and can see no connection between it and the mains earth or chassis. Are there any other tests I might try before tying two together to make a split psu : 24/0/-24 ?
They are Power-One MAP55-1024 @ 2.5A.
Old 6th October 2005, 07:33 PM   #2
ericallan's Avatar
Default Update
- Power-One have very kindly replied to an email and said that the output earth is floating.
Anyone want some?
Old 9th October 2005, 11:43 AM   #3
Leolabs is offline Leolabs  Malaysia
Leolabs's Avatar
Send a message via MSN to Leolabs
Cant do much with only 2.5A
Old 9th October 2005, 01:18 PM   #4
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Sort of agree although I have run a GC (both channels) off one of the 8080 modules (+12 volts/6A and -12 volts/1A). But you will need efficient speakers!
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 11th October 2005, 08:05 PM   #5
ericallan's Avatar
Wouldnt I have a total of 5 amps with 2 supplies in parallel?
Old 11th October 2005, 08:14 PM   #6
Nuuk's Avatar
I believe so! I have not run mine in parallel though!
Old 12th October 2005, 12:30 AM   #7
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Power-One had the misfortune of orienting a large part of their business towards Cisco in the late days of the internet bubble. As a result their stuff remains comparatively cheap. They make very good supplies.
Old 12th October 2005, 01:06 AM   #8
wes-ninja250 is offline wes-ninja250  Canada
wes-ninja250's Avatar
Don't forget, you can't just run any two arbitrary SMPS in parallel. FWII, there are usually synchronization issues.
Wes
Do daemons dream of electric sleep()?
Old 12th October 2005, 07:21 AM   #9
sagarverma is offline sagarverma  India
sagarverma's Avatar
don parallel two psu,there are compatibility issues that need to be addressed.
during low of one there can be high of other frying up whole of the system.so don,t do it in any case.serious warning
Old 12th October 2005, 01:25 PM   #10
ericallan's Avatar
Thanks for that - I'll give them a go in series anyway, just for the hell of it.
Cheap 24v SMPS - advice neededHide this!Advertise here!
advice needed for cheap line array tweeter zobsky Multi-Way 23 15th September 2009 04:24 PM
SMPS PCB Layout Advice microsim444 Power Supplies 2 22nd January 2009 07:27 AM
Cheap, high power SMPS MotoMan_Yz400 Class D 64 16th April 2008 05:15 AM
A cheap 12v SMPS for class D Foxx510 Class D 0 22nd December 2006 07:55 AM
SMPS controller advice Johan_Ch Parts 11 1st September 2003 06:08 AM
Copyright ©1999-2017 diyAudio
