2x9V and 200VA xformer, what to do?
Get two of the transformers. Take one transformer and put the windings in series to give you 18v @ 11 amps. Then do the same on the other. That'll give you 25 VDC or so after rectification. Perfect for a LM3875 gainclone, or even better for a LM3886 or LM4780 (paralleled) into a 4 ohm load.
Then make yourself a nice 6 channel home theater amp :D Or just have massive overkill for your power supply.
