Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 6th October 2005, 01:59 AM   #1
pjpoes is offline pjpoes
Send a message via AIM to pjpoes
Default oscillation
How would I know if my amp is oscillating. Someone mentioned that one reason it might be running hot all the time is that its oscillating. I get no weird noises, I see no oscillation in the speaker unless its supposed to be, such as with music. I dont know much about amps oscillating, but I always thought you could see or hear it.
As for how hot, I still dont know exactly. When the amp is on and plugged into a preamp and 8 ohm speakers but no music is played, the amp us warm to the touch. At the temp I would have expected it to run at if it had been playing all day. If I then play music for an hour or two, the amp gets quite hot. Not so hot that it shuts down, and not so hot that I can't touch the heatsink, but hot enough that I wouldn't want to hold my hand on it for a long period of time. Given that skin burns at around 170 degree's, I want to say that the amp must be less than 170, infact probably less than 150 degrees, but not much less if any. The heatsink might be too small, but looking at what some people have used, I would have thought its enough. I think I may have misjudged, I never bothered to do the math with it. Anyway, if anyone could let me know if oscillation does sound like a possibility and why it might be happening so I can find it, I would appreciate it. Thanks.
Old 6th October 2005, 02:20 AM   #2
lawbadman's Avatar
What chip amp is it?
Which circuit diagram did you use?
What are the dimensions of the heatsink?
A picture would be quite helpful also.
<a href="http://www.danasoft.com"><img src="http://www.danasoft.com/sig/lawbadman.jpg" border="0"></a><div style="font-family:arial,sans-serif;font-size:11px;"><p>Sign by Danasoft - <a href="http://www.danasoft.com">For Backgrounds and Layouts</a></p></div>
Old 6th October 2005, 02:45 AM   #3
I used the Audiosector LM3886 premium kit. Only differences is that the powersupply has the caps bypassed with some small value BG's.
350va 25-0-25v transformer. The heatsink is one from MPJA.
http://www.mpja.com/productview.asp?product=14674+HS
Old 6th October 2005, 03:28 AM   #4
Your amplifier may be oscillating, even if you canīt hear it.
The amplifier can oscilate at frecuencies not audible (50 to 100 Khz or more).
If possible try, to use an osciloscope to see the output.
Other way may be a frequency counter or multimeter with frequency function.
Your "hand thermometer" indicates that the chip is not too hot.
Try with the input shorted, to see if the temperature goes down.
hope this can help
Miguel A. Font
Old 7th October 2005, 06:01 AM   #5
sagarverma's Avatar
hey tla
amp chips have a freq band of operation.so how can there be ultrasonic oscillations.
hook up amp o/p through solid power res. to an oscilloscopes and see for oscillations.
Old 7th October 2005, 01:26 PM   #6
just another
wintermute's Avatar
Hi pjpoes,
If you don't have an oscilloscope then you could try this simple circuit that was suggested to me. http://www.diyaudio.com/forums/showt...175#post680175
It won't tell you definitively whether you have oscillations, but will probably give you an indication.
I didn't think Peter did an LM3886 kit???? Do you have long wires from your input jacks to the amp pcb, or long power supply wires?
Tony.
Any intelligence I may appear to have is purely artificial
Some of my photos .... Finally getting back to working on my MTM after a 4 year Hiatus.
Old 7th October 2005, 02:10 PM   #7
sss is offline sss
sss's Avatar
Send a message via ICQ to sss
if the amp is getting hot because of oscilation then u probably never gonna hear it .
the reason the amp is gettin hot during oscilation is because the output transistors (of the chip amp) are unable to swith of fast enough with a wery high oscilation frequency ,so they stay in "on mode" and getting very hot
plus , the oscilation can accur where there is input signal and stop when there is no signal .
the only oscilation u can hear is a low freq oscilation that wont heat up your amp , just make anplieasent noise
if you are not living on the edge you are taking too much space
Old 7th October 2005, 02:49 PM   #8
I mis-spoke, its an lm3875 kit. Does that change anything that was said so far.
My input leads are kinda long, about 10-12 inches right now. I made them up long because I wasn't sure how long they would need to be for the inclosure, so I did that.
Old 7th October 2005, 03:32 PM   #9
just another
wintermute's Avatar
no I don't think it matters too much, just checking .... are your input leads sheilded cable or just plain wires?? I was thinking that if they are long (and unshielded) they may be picking up some rf, potentially causing oscillation.
Tony.
Thread Tools
807 AB2 oscillation maybe? Craig405 Tubes / Valves 27 25th March 2008 10:01 PM
CDP Oscillation emmasdad Digital Source 0 4th January 2006 03:54 PM
Oscillation raveenvijendren Solid State 15 18th December 2005 11:16 AM
oscillation?? wintermute Solid State 8 13th July 2005 01:45 PM
Oscillation udip Solid State 5 31st January 2005 06:43 PM
Page generated in 0.25040507 seconds (79.45% PHP - 20.55% MySQL) with 10 queries
Copyright Đ1999-2009 diyAudio
