Help: Need to lose some volts
Old 5th October 2005, 07:31 PM   #1
Decker is offline Decker  United States
Default Help: Need to lose some volts
So I had this great idea to build a chip amp with LM3875s out of the Harmon Kardon Citation 12 chassis that was gathering dust in my garage. The chassis is thick steel and it has separate power transformers for each channel. So far, so good. I added a line filter, a power switch and some new 15k uf caps. But I didn't think ahead far enough. The power supply puts out +/- 42.5 volts. Too much for the LM3875, which has a max PS voltage of +/- 42 volts according to the spec sheet. Can anyone suggest how I can drop the PS voltage a bit, short of regulators? I've never tried a Pi filter in a transistor power amp, or heard of one, so I'm wondering if there is a sonic penalty to this approach. I thought about using a bucking transformer to lower the line voltage in, but there isnt much space on the chassis left after adding the new caps. I could try to squeeze in simple regulators, or capacitance multiplier filters, but if there is a simpler way, I'd love to hear it. Suggestions?
Old 5th October 2005, 07:55 PM   #2
azira is offline azira  United States
Do you really need to shave just 1 Volt? How about a diode or two?
Old 6th October 2005, 03:28 AM   #3
No, that would still be too close to the edge for me. Ideally, I would like to get to +/- 30-35 volts.
Old 6th October 2005, 03:57 AM   #4
mpmarino is offline mpmarino  United States
mpmarino's Avatar
hmm, it would be pretty cool if you built a Citation 12 in that chassis Maybe Nelson's mosfet variant?
Otherwise, you could easily lose a few volts with a CRC and get some sonic benefit IMHO.
Crazy Yankee.
Old 6th October 2005, 05:01 AM   #5
I_Forgot is offline I_Forgot  United States
I_Forgot's Avatar
Default Re: Help: Need to lose some volts
How about an outboard transformer? Companies that sell transformers for using equipment from other countries make all sorts of voltage ratios and they come prewired with power cord and outlet. Specifically, I am thinking of a Japanese/US conversion transformer- 100V on one side 117 V on the other. If you connect the 117 side to the power line and the 100V side to the amp, the PS voltage should drop about 17% (about 7 volts) which puts you right where you want to be. No modifications/chassis space required.
I_F
Old 6th October 2005, 05:54 AM   #6
lgreen is offline lgreen  United States
lgreen's Avatar
Default crc or reg
without adding a 3rd transformer to drop the line voltage to your other 2 transformers, your only options are a CRC power supply or voltage regulators. Remember that the LM3xxx regs just need less than 45 V input to ouput differential so should be well within their operating permaters with your transformers. Or you could do a CRC supply and that would be fine.
As a bonus, both techniques will give you a better amp.
Old 6th October 2005, 06:31 AM   #7
EWorkshop1708 is offline EWorkshop1708  United States
You could make a special transistor-capacitor filter.
Use diodes to drop the volts, and a transistor attached to a heatsink to carry the load. The capacitors and resistors provide RC filtering network to reduce ripple.
Now for two rails +/- you would have to make two of these, but one would have opposite polarity and use PNP instead.
Old 6th October 2005, 07:17 AM   #8
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
all those solutions will dissipate power and heat for no purpose .
the best u can do is
1.change the transformer
2.reduse the secondary winding turns of the original transformar ,should be very easy/simple to do ,depending on the type of your transformer.
if you are not living on the edge you are taking too much space
Old 6th October 2005, 07:43 AM   #9
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Decker, I wouldn't worry to much if you have +-42.5 V unloaded.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 25 pcb's in interest.
Old 6th October 2005, 09:55 AM   #10
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
There are a number of people running 3875s that high or even a bit more, and they still have their smoke inside.
But me, i'd at least do a CRC -- as much to get a better suppl as opposed to dropping V. A CLC or CLCRC would be even better -- if you can figure out where to stuff the parts. It's been over 30 years since i had my Citation 12 so i'm a bit vague on the chassis details.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Help: Need to lose some voltsHide this!Advertise here!
Did you lose a case of CD's at RMAF? Jon Ver Halen Pass Labs 0 20th October 2008 03:34 PM
power transformers 220 volts to 110 volts garydmd Chip Amps 3 7th April 2007 03:52 PM
Gainclone is on 120 volts will it be fine at 220 volts? Jimmy154 Chip Amps 7 29th June 2005 01:10 AM
How much flux do you lose if... 454Casull Multi-Way 11 18th January 2005 10:05 PM
Do I lose power when parafeeding? Bas Horneman Tubes / Valves 2 26th March 2004 03:30 PM
