| Chip Amps Amplifiers based on integrated circuits |
#21 | |
The article from Elektor last summer points the way. ("Compact 200W Output Stage", Elektor, July-August 2005). If you don't subscribe to Elektor (you should) , you can purchase a PDF of the article from their website. |
#22 |
You have made some very good points.
So what is considered the best output configuration? |
#23 |
Banned
Just a simple minded idea. According to Peavey at http://www.peavey.com/support/techno...s/classact.cfm there is also design philosophy quoted from page 2 MOSFETS "properly designed and used within design parameters, an amplifier will not have a characteristic sound -- the positive sound qualities attributed to vacuum tubes are actually artifacts of non-ideal preformance and musical sounding overload beyond electrical clipping". With this design philosophy in mind http://www.genzbenz.com/?fa=detail&m...sid=422&cid=95 states "with seperate FET and 12AX7 tube channels that can be selected independently or mixed togeather creating endless tonal possibilities". So just the rigid topologies of A, B, AB et all and rigid electronics theory and application, can still leave room for design philosophy while investigating output stages, even odd FET and TUBE parallel output stages philosophy. Mark |
#24 |
Banned
Written by Nelson Pass of Pass Labs www.passlabs.com/downloads/articles/seclassa.pdf We've heard Triodes, Pentodes, Bipolars, VFMET, MOSFET, IGBT ... and appreciation of audio is a completely subjective human experience ... we should no more let numbers define audio quality than we would let chemical anaylsis be the arbiter of fine wines ... why are we looking to reduce subjective experience to objective criteria anyway? Mark |
#25 |
Banned
With a GN X 3000 from www.digitech.com a musician can simulate 40 amp models and 25 speaker cabinets and with a POD X Live from www.line6.com a musician can simulate 36 amp models and 24 speaker cabinets. So why should the LM4702 driver be limited to the subjective sound of 1 output stage, expecially calling this 1 output stage the "best"? Some like TUBE flavor. Some like BIPOLAR flavor. Some like MOSFET flavor. Some like hybrid flavors. So why 1 "best" ouput stage for all subjective human listening experience? Mark |
#26 |
Banned
National Semiconductor writes some philosophy on LM4702: "Sound quality can be a very heated and subjective debate. However, some feel that there are differences that can be heard between different pieces of equipment and that almost all of these can be quantified ... a significant amount has been written in the audiophile press about how different types of passive components affect perceived sound quality ... [in our prototype] all of the passive components used in the demo amplifier are standard". www.national.com/an/AN/AN-1490.pdf#page=7 at topical subdivisions sound quality and parts selection. So I guess one philosopy of ouput design, is to start with the stardard parts and then evolve into the more esoteric parts, while always listening to the subjective sound output and then double checking the subjective with the objective quantified. Mark |
#27 |
Banned
NS has already made an output stage philosophy at the FAQ question entitled "How do I get an ouput power of 300 watts or more per channel for the LM4702". NS's answer: The output stage will need to be composed of 3 NPN/PNP output pairs. It is also possible to get 100 watts with 1 output pair and 100- 200 watts with 2 NPN/PNP output pairs. This philosophy is 1 pair then 2 pair then 3 pair or 2 transistors per channel then 4 transistors per channel then 6 transistors per channel, which is a standard design philosophy. http://search.national.com/iphrase/q...gories=1phrase Mark |
#28 |
Banned
Alan Blumlein earned 128 patents including British 394325 for stereo audio by the time he died at age 39. What would AB do with LM4702, just another conventional 2 channel stereo circuit? http://www.ieee-virtual-museum.org/c...=1234681&lid=1 Mark |
#29 |
Banned
This old May 1992 Electronics World image showing part of Tosbiba's application note X3504 may be one of the first DIY notes available for use of IGBT in audio output stages citing use with a GT20D101. Does anyone have any newer IGBT audio ampflier output stage schematics? www.audiodesignguide.com/tra/igbtsch.jpg Mark |
#30 |
Banned
UNETTO minimal power amplifier uses class A driver (which LM4702 is) and class AB push pull output stage. Note says IGBTs are voltage sensitive devices and a small change in the input voltage generates a large change in the output current. This would be an odd mixture with LM4702 semi-constant current (for low noise) with large voltage change to next drive a low voltage sensitive IGBT output stage with a high current out put swing. The "odd couple amp". http://digilander.libero.it/essentia...netto_home.htm Mark |
| Lm4702 Bpa | halo0925 | Chip Amps | 19 | 13th November 2006 04:47 AM |
| Lm4702 BPA | halo0925 | Solid State | 0 | 9th November 2006 10:26 PM |
| Page generated in 0.13297 seconds (83.34% PHP - 16.66% MySQL) with 11 queries |
