Old 25th March 2008, 02:15 PM   #101
ionomolo's Avatar
Send a message via MSN to ionomolo
I can't see any reason for which these shouldn't work, but i can't find any beta-ic plots so maybe the driver will have some trouble driving them loud. LME49810 and LME49811 are better right now.
The transistors can give > 10A peak which should give more than 100Wpk with 45º loudspeakers, which is probably loud enough for you. Paralleling a pair would help preventing beta droop and make a more rugged amplifier.
Remember to use nice thermal compensation.
Good luck!
Old 25th March 2008, 03:02 PM   #102
jackinnj's Avatar
Originally posted by bobekucor
hi, just wanna ask is it possible to use 2SD2488 and 2SB1620 darligtons in building amp with Lm4702, i have 5 pairs tooked from Sony HT receiver, and wanna build something that would sound good but also have enough power (maybe using a multiple darlingtons at output?)
so I would appreciate if someone`d be kind to tell me how to do that in schematic, I am a quite newbie with this stuf
I think these parts are from the old Sanken product list -- they are probably sufficiently beefy for the task. I have used MN2488, MP1620; TIP142, 147 etc.
Old 25th March 2008, 03:10 PM   #103
thanks for answers, could you explain me or draw in short how to connect multiple darlingtons, I am planing to use this Schematic
btw sorry for so many questions
Old 25th March 2008, 03:28 PM   #104
jackinnj's Avatar
Multiple Darlingtons (i.e. Darlingtons in parallel) are NOT a good idea.
Old 25th March 2008, 03:50 PM   #105
ok, thanks again, now I`m gonna do some job
Old 25th March 2008, 11:13 PM   #106
When we worked on Darlingtons in parallel with the LM4702 we could never get it stable. Agree with above post, don't bother.
-SL
Old 25th August 2008, 10:58 PM   #107
Send a message via MSN to thelordash
Default I need one of these
where to get this LM4702 i can't find it anywhere pls help i know its an old post
Old 26th August 2008, 01:14 AM   #108
jackinnj's Avatar
I have them on my webstore -- as I bought a bunch a year ago.
http://www.tech-diy.com/Store/Drivers.htm
Old 27th August 2008, 08:55 AM   #109
glennb is offline glennb  Australia
I can be done with good results, but the Emitter resistors required to get decent current sharing are quite high in value. My tests many years ago revealed that 0.5 Ohm was required to get below 10% mismatch in current. I've used up to 4 in parallel without stability problems (TIP142/147).
I also used 47 Ohm stopper resistors on all the Bases. This probably helps more with stability than current sharing.
Glenn.
Old 31st August 2008, 01:30 AM   #110
Shaun is offline Shaun  South Africa
Shaun's Avatar
Originally posted by JustBuildLspkAS
hi everyone.(sorry for my poor english)
Need help for the BJT O/P stage for newbie ss amp. design as me.
I would like to use this output stage for my amp . How I chosen the correct bias for this circuit ,(for the out put transistor I need run idling 50-100mA / piece)
Hi JustBuild
That circuit looks interesting, and is presently my preferred configuration for tagging onto an LME49811, of which I have a few samples. Any idea why it has dual (60V/55V) rails?
Shaun Onverwacht
|||||||||| DON'T PANIC ||||||||||
Lm4702 Bpa halo0925 Chip Amps 19 13th November 2006 04:47 AM
Lm4702 BPA halo0925 Solid State 0 9th November 2006 10:26 PM
Page generated in 0.16579 seconds (53.16% PHP - 46.84% MySQL) with 11 queries
