| Chip Amps Amplifiers based on integrated circuits |
#11 | |
Are you mad? If you use de-ionized water, it'll likely eat the hell out of the metal parts and if that doesn't kill it, the water will still conduct electricity and short out. Mineral oil is the only cheap and safe way to go. |
#12 |
You would still need a heatsink to draw the heat away from the GC into the surrounding liquid better. Maybe a much smaller one, but you would still need one.
Also, I played around with my multimeter, and noticed that Water and Peroxide conduct good, 1-10K ohms, but 91% Alcohol hardly gets a reading on my meter. My meter reads up to 30Megohm and I had to have the prongs almost touching to get readings. Lowest I got was 15 Megohm before prongs touch. I would think that submerging a GC with a small heatsink in Alcohol would do the trick. |
#13 |
Mineral oil doesn't conduct heat well enough, actually the part may even become heat saturated. Dip your hand in a vat of hot oil, enough to cause severe burns, now rub baby oil on it and tell me how cool it is, lol...
Polo..
Safe_Cracker :O)~ |
#14 | |
Something gives me the idea you allready did this....
#15 |
Safe_Cracker :O)~ |
#16 | |
my computer waterblocks are holding on just fine after two years of using the stuff.. for a tast it'l work just fine. it did when i submerged my old computer in the stuff to see if it was anything to shout hourray for.. not that it was anyways, didnt come over 2ghz on my xp1700 that does 2.3 on air. but back to topic.. |
#17 |
diyAudio Editor
It eats up the metal to a point- a point where it will then conduct-because it is then ionized. So why bother with deionized.
The fluid coolinfg of amps has been discussed a LOT in various threads and can be found by searching |
#18 |
fluid cooling is different from actually submerging the amp in a liquid. I've not seen that done before, so I would like to see you try.
Kind of the opposite, but after reading about how certain dialetrics were "almost" as good as a vacuum, my idea was to vacuum seal or evacuate a cable or preamp. |
#19 |
Electrons are yellow and more is better!
So far electrical things may be in oil but I have never heard about electronics in water of the purpose of cooling. I'll guess time will tell and give us the answers.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#20 |
Hmmm. Liquid cooled amps?
http://www.vongaylordaudio.com/product_html/prouni.htm I would say if you can't afford the flourinert (isn't it $300/gallon?), mineral oil is the way to go. There have been countless overlcockers who've submerged their machines in mineral oil for cooling experiments. Most of the rigs that I've seen put the components in a container and fill it with mineral oil. They then place the container and oil combination inside the refridgerator. The oil aids heat transfer and also keeps condensation from forming on any of the components. |
| Freebird + Gainclone = "integrated" gainclone? | bikehorn | Chip Amps | 9 | 5th January 2006 03:07 PM |
| Big gainclone | steven344 | Chip Amps | 10 | 23rd November 2005 07:58 PM |
