Old 11th December 2005, 04:18 PM   #21
Nice amp! I would be interested in building the BPA300 for sure. Finally a chip amp that is useful!! Is the board your design or one that is commercially available from Hong Kong? Anyone here in for a group buy on this sort of board. Since Pinkmouse is pretty burried with other PCB requests I could ask a friend over at GE Medical that designs their PCB's to do this for us. He is has been itching for something like this do to on the side.....
If this board is not commercially available then we could just copy it for the most part. If anyone would like to give any input as to modifications or changes please feel free to do so.
Mark
Old 11th December 2005, 04:50 PM   #22
pinkmouse's Avatar
Pah, I turn my back for five minutes and you're already chasing other PCB designers... MEN! You're all the same!
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 11th December 2005, 04:59 PM   #23
No, not really but you were the one that listed all the PCB's that you have to do.... excluding the GG of course. I would much prefer that you do it but do really you have the time???? I think this would be a very worthwhile project but I would probably do it with the servo as reccomended by National Semi. We could eliminate the input caps. I am in the middle of reading the N.S. paper and the servo is not that big of deal.
Mark
Old 11th December 2005, 05:08 PM   #24
pinkmouse's Avatar
S'alright Mark, I forgive you!
I have been tempted by the BPA style designs before, but I was going to use the OPA chips, as I still have a good few to use up in something or other. That PCB design does look good at a glance, and if your mate's up for it then with the help of the schema you should be able to do a reasonable clone.
Al
Old 11th December 2005, 06:13 PM   #25
I_Forgot's Avatar
It looks like a really nicely made amp! Well done!
How are you getting the heat out of the box? I see holes in the top, but none in the bottom, and the heatsinks don't look very big for a 300W amp, even if it is class B. Have you monitored the heatsink temperature?
I_F
Old 11th December 2005, 06:15 PM   #26
jackinnj's Avatar
If you take two or 3 "bridge boards" and parallel them with the LM4780 you will, equivalently, have 4 or 6 LM3886's -- but you have to be very careful about selecting resistors if you go servo-less.
since I have the Gerber file already, I was thinking of incorporating the servo -- as you can see there is plenty of real-estate on the board for a dual opamp, associated components and localized V+ - regulators. I would prefer to do it in surface mount, however.
the OPA's would make a great buffer but there seems little point incorporating them on the amplifier board.
Old 11th December 2005, 06:23 PM   #27
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
very nice and clean work
if you are not living on the edge you are taking too much space
Old 11th December 2005, 08:23 PM   #28
It would seem to me though that more LM3886's(or4780's for that matter) paralleled would allow a considerably lower output impedence than the lower count 4780 route. I think that was one of the main reasons that Rowland went this route.... if that be true then that would certianly pose a big advantage over a lower chip count. Aside from the several dollars of extra parts I can't see why not servoing them would be a big deal. I would definately want to get rid of the input cap.
Mark
Old 12th December 2005, 12:55 AM   #29
alexw88 is offline alexw88  Hong Kong
Mark
Mark, I am not selling these boards but if you like you can use my gerber files to order some.
Attached are the gerber files for the PA150 board, but you still have to make your own DRV134 board because I get mine from a Taiwan web site : www.my3c.net
My Audio Page
Old 12th December 2005, 01:00 AM   #30
I_F
If you look at post #4, you will see threr are holes at the side of the case.
When Idle, the heatsinks are just warm to touch. At full load, the heatsinks gets very hot, but I can still leave my hand on it, so I think the temp. at full load is about 80 degree C.
My Audio Page
BPA300 mono block alexw88 Group Buys 252 27th December 2011 03:35 PM
Mono block restoration soundfan Tubes / Valves 6 29th January 2005 12:27 PM
mono block amp Mark Osborn Solid State 11 16th March 2001 06:07 PM
Page generated in 0.10896 seconds (87.11% PHP - 12.89% MySQL) with 11 queries
