Old 13th November 2007, 06:46 AM   #101
codegen is offline codegen  Norway
Send a message via MSN to codegen
Hi alexw88!
Very nice amplifiers you made. do you make the chassis your self or is it possible to buy somewhere?
Old 15th November 2007, 02:39 AM   #102
alexw88 is offline alexw88  Hong Kong
The chassis is from www.my3c.net
http://www.my3c.net/product/detail.a...6&ky=&pid=1902
http://www.my3c.net/product/detail.a...6&ky=&pid=2737
My Audio Page
Old 18th March 2008, 02:50 PM   #103
dear all, who i can buy a pcb of PA150 ?
thanks for all!!!
Old 20th March 2008, 11:03 AM   #104
xiphmont's Avatar
Send a message via AIM to xiphmont
Originally posted by Mark A. Gulbrandsen
Aside from the several dollars of extra parts I can't see why not servoing them would be a big deal. I would definately want to get rid of the input cap.
Mark
...or shield it. I see you're getting 50Hz and harmonics coupled in on your test plots. The big naked input cap is a possible source. Worth checking for for another 10dB of free noise floor.
(I just happened to recently find that's where the last of the PSU noise in my own current design was coming from. I opted to kill off the coupling caps and go to a transformer input [CMLI-15] rather than a servo.)
"My name's Monty, and I break things."
"Hello, Monty!"
Old 4th May 2008, 02:30 AM   #105
madam is offline madam  Hungary
Default Buildong
Hi all, I'm new in here, but I'm building these amps at the moment.
will make some changes on the pcb (some parts are more easy to find here in a different size)
The conductor will be silver, and with 100um thick (each side)
Would like to ask some questions from Alexw88, but I'm blocked -PLS check your mail on www.shine7.com
P.S.: I could send PCB-s naked and filled as well in about 3-4 weeks if it's needed 2 someone (Hungary/Europe) !!!
Old 5th May 2008, 03:25 AM   #106
madam, I don't get your email, if you have questions to ask, you can post it here. There are many diyaudio members here to help
My Audio Page
Old 5th May 2008, 04:31 PM   #107
First of all, I would like to know what's changes if I use a biger (10 pF) capacitor? It's hard to find this 8,2pF at 200V in SMD.
he other H2F is dhe Dale WSR resistor. What shall I use??? wirewound?
I would like to know, why did you choose the LL 1545 A?
I would like to use the LL 1690.
I`ve tryed 2 understad the differences between them, but I`m not good enough for it.
Could you please check it for me, and give me some suggestions in it???
I don`t know what kind of pre-amp will I use with it, but if Good
helps me I will buy a tube thing from www.transcendentsound.com
I would like to deliver 2X150 Watts (on 8 Ohm) per SIDE
So I build a dual mono push-pull amp per side for biamping.
I`m not shure how shall I connect these audio transformers in this case?
just simply split the signal after the transformer?
or I should get 2 transformer per side? (this would make me a bit unhappy a bit)
Old 5th May 2008, 05:47 PM   #108
HIPCHECK's Avatar
Madam
ill donate the SMD resistors you need, email thru forum.
Are you getting boards made?
If a inch of duct tape will fix it, 3 feet should fix it for life!!!!
Old 6th May 2008, 02:00 AM   #109
10pF should be fine, the value is not very critical.
For the Dale WSR resistor, you can use any 3W resistor instead, wirewound would be fine.
I use LL1545A because it is available from the online stone that I used to buy things. LL1690 would also work, may be even better as it can handle higher level.
"So I build a dual mono push-pull amp per side for biamping."
If you want to do bi-amp, would you use a digital crossover to split the signal for the tweeter and woofer? In this case you need 2 transformers per channel.
or if you just feed the same line signal to 2 amps, then you can split the signal after the input transformer, in this case only 1 is needed.
My Audio Page
Old 6th May 2008, 02:49 PM   #110
Thanks for the infos, than I will buy the 1690.
I'm not shur about this bi-amp stuff, but I have a nice speaker ( home made REAL high end stuff) and I want to amp them from a stereo (or in this case a dual mono amp to avoid ground loop in my sistem (since the Xo's are on a separeted board)
I don't want to use any digital what'snotever in my signal path.
I will just simply split the signal.
Thanks for the info Alex!
Hipchek: I will have a lot of board.
Made with 100 micron silver, but some thigs must be changed (input, output and power connects, becouse I could't find those thing at that size here)
everyting will be the same
will cost about 10$ plus P&P per board, but I'm not shure yet.
And It's will be available all (or olny the SMD parts) insalled. 4 another small charge.
I can't send mail, I'm under moderation at the moment.
It's would be fine if you could send me the resistors (0,1% or tighter) (i will build 16 boards for the start, and mor in the future) and I will send you some boards in the prices of the resistors?? Is it O.K. 4 you????
BPA300 mono block alexw88 Group Buys 252 27th December 2011 03:35 PM
Mono block restoration soundfan Tubes / Valves 6 29th January 2005 12:27 PM
mono block amp Mark Osborn Solid State 11 16th March 2001 06:07 PM
Page generated in 0.15201 seconds (63.29% PHP - 36.71% MySQL) with 11 queries
