Single sided non inverting LM3886 PCB - Page 4 - diyAudio
Old 31st March 2009, 04:36 PM   #31
Originally posted by zinblade19
please refer to the PSU schematic too (attached here)
a centre tapped transformer must use a single bridge rectifier to create the dual polarity supply.
The dual rectifier version you have shown can only be attached to dual secondaries.
Look up National's datasheet for the Cs description.
your schematic shows 1n5F and 220pF as the RF attenuation filter after the 1k0 plus Rs from your source.
Let's assume Rs=100r.
the RF filter ~ 1k0+100r and 1n5F+220pF ~1.9us.
The normally recommended range for the RF filter at the front end of a power amp is 0.5us to 1.5us.
You need to reduce your capacitor values and check the Rs of your source.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 31st March 2009, 04:51 PM   #32
Sorry,didn't get it........once again please.
http://www.sengpielaudio.com/calculator-RCpad.htm
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 31st March 2009, 04:56 PM   #33
Hi AndrewT,
thanks for your reply.
I would be using a centre-tapped transformer,
& a single bridge rectifier..........
I just wanted to show u the filter ckt of the rectifier..
I would be using EI transformers, any major disadvantages??
(didn't see anyone using it here)
Old 31st March 2009, 05:04 PM   #34
ollebolle's Avatar
If you compare a 200VA toroid with a 200VA EI you will notice the toroid is smaller!
I have read that toroid's are more efficient to. Lower losses.
Old 31st March 2009, 05:10 PM   #35
toroids are generally more efficient. The result is that they run cooler.
Toroids are generally lower regulation. The result is that the voltage sags less under load.
Toroids offer size and weight advantages to manufacturers of amplifiers that do not apply to us DIYers.
Toroids pass more high frequency artifacts. This results in more noise getting through the PSU to the circuit beyond.
A high quality EI designed for good regulation and low magnetic fields will perform very well, but it will weigh far more and cost far more than an equivalent high quality toroid.
regards Andrew T.
Old 1st April 2009, 07:16 AM   #36
Originally posted by AndrewT
Mute and GND should not share a trace with Signal Ground and NFB lower leg.
(in post #29)
Hi Andrew!
in the PCB layout Mute & gnd does not share a trace with signal gnd or NFB lower leg.
Anyway, can you tell me -- what would be the result with it???
lm3886 single sided pcb ryan750 Chip Amps 56 27th May 2015 02:35 AM
My tiny single sided LM3886 PCB layout. :) Russ White Chip Amps 74 14th September 2008 06:53 PM
pa100 pcb single sided layout lm3886 dgaxeman Chip Amps 6 24th May 2006 01:45 AM
Copyright 1999-2017 diyAudio
