Single sided non inverting LM3886 PCB
Old 9th November 2008, 06:13 PM   #21
Ulew is offline Ulew  Sweden
Sorry for bringing upp a rather old thread, but I have some questions! AndrewT said that one rectifier is not correctly shown, but whats wrong with it?
Those rectifiers aren't available in Sweden (haven't found them, anyway) so what kind can I use instead?
Old 9th November 2008, 07:26 PM   #22
R.I.P.
you haven't posted a layout, so who's are you referring to?
regards Andrew T.
Old 9th November 2008, 07:29 PM   #23
The one the thread is about!
Old 9th November 2008, 07:42 PM   #24
pacificblue is offline pacificblue  Germany
AndrewT refered to the PSU in post 5, because dual rectifiers are used with a center-tapped transformer. They only make sense with a dual secondaries transformer.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 9th November 2008, 07:53 PM   #25
Ah, okay!
What about the rectifierbridge, what should I look for?
Old 10th November 2008, 07:18 AM   #26
R.I.P.
use the 4diode integrated rectifier bridge, available in the high current metal cased version or in lower current plastic cased and 4-in-line pins.
Alternatively, use To220 single diodes to construct a bridge
or use 1n5402/3/4 to create your own very cheap bridge.
Sugden use 8 off 1n5404 to charge +-20mF to +-75Vdc and I have never had a failure.
regards Andrew T.
Old 29th March 2009, 07:05 PM   #27
zinblade19 is offline zinblade19  India
Originally posted by ArtiomR
But I think, there is one mistake in your schematic and PCB - R2 resistor should be connected between Cin and R1, so that they form a high pass filter
[/B]
Hi AndrewT,
is the schemetic originally posted by tla-Audio wrong, as mentioned??
Is this a good design for the lm3886??
I'm thinking of using it, any modification??
(would be using 18-0-18, 3A trans for each ch)
the schematic is attached here......
Old 29th March 2009, 08:17 PM   #28
You could leave CIA away. CIB could become 47 F then.
You will have to recalculate Rm, if you use ~24 V DC rails. Should be 10..12 k then.
Old 29th March 2009, 09:46 PM   #29
R.I.P.
compare that schematic to National's recommendations.
It has duplicated the RF input cap. 1n5F will probably take off too much treble. I reckon 1.5us is top limit.
Both Cs are wrong. They should include an electrolytic on each polarity and should connect together before going to Power Ground.
L1 should have a resistor in parallel to create the HF load. Somewhere between 2r7 and 10r.
Mute and GND should not share a trace with Signal Ground and NFB lower leg.
regards Andrew T.
Old 31st March 2009, 07:51 AM   #30
Hi!
Sorry,didn't get it........once again please.
polarity and ......
[/B]
what value electrolytic should I use??
please refer to the PSU schematic too (attached here)
Single sided non inverting LM3886 PCBHide this!Advertise here!
lm3886 single sided pcb ryan750 Chip Amps 56 27th May 2015 02:35 AM
My tiny single sided LM3886 PCB layout. :) Russ White Chip Amps 74 14th September 2008 06:53 PM
pa100 pcb single sided layout lm3886 dgaxeman Chip Amps 6 24th May 2006 01:45 AM
