Single sided non inverting LM3886 PCB
Old 7th August 2007, 11:35 AM   #11
beetel is offline beetel
Capacitor CI shown near the word "GND" on PCB is not shown in schematic anywhere ? or may be I missed it.
regards
Old 7th August 2007, 12:36 PM   #12
the PSU in post 5 is wrong.
It shows a dual rectifier arrangement feeding the positive and negative halves of the PSU. This side os OK.
The transformer is shown as centre tapped. This is wrong.
The four connections on the PCB MUST be connected to dual secondaries.
regards Andrew T.
Old 7th August 2007, 12:38 PM   #13
regards
Hi Beetel,
look again and you will see that (Cia+Cib) are parallel to Ci.
regards Andrew T.
Old 8th August 2007, 10:58 AM   #14
What is the value of Ci ?
thanks
Old 8th August 2007, 12:10 PM   #15
precise value hardly matters.
A low value film cap of about 1% of the electros is close enough.
Some say polypropylene is good here but they tend to be bulky and more expensive, but getting cheaper by the month.
Polyester is probably next best followed by Mylar (a lower quality version of ester film). PES are small and cheap.
regards Andrew T.
Old 8th August 2007, 02:50 PM   #16
Thanks for reply Andrew
In the PCB file the Ci is shown as an electrolytic capacitor.
regards
Old 8th August 2007, 03:02 PM   #17
yangsmm is offline yangsmm  South Korea
Default Thanks all of you!
Thanks all of you. I needed the schemetics of lm3886. I'd like to make audio amps using lm3886.^^ Thanks a lot.
Old 8th August 2007, 06:03 PM   #18
that must be an oversight.
He appears to have pulled up the wrong symbol.
There is little advantage in adding another polarised electro in parallel to the back to back polarised electros.
He surely intended to show a low ESR, low inductance, low distortion, bypass across the electros. The bypass will hopefully handle all the mid and high frequencies. The electros will bring up the bass.
regards Andrew T.
Old 5th October 2007, 03:15 PM   #19
tla-Audio has used two 2.7ohms /2w resistors in power supply and one 2.7 ohms/2w in amp circuit.
What type of resistors should be used here ?
Carbon film, wirewound, metal oxide, fusible or something else ......
thanks
Old 22nd October 2008, 11:11 AM   #20
ollebolle is offline ollebolle  Sweden
ollebolle's Avatar
I have just etched my first board using this design
I will etch the second one soon.
Single sided non inverting LM3886 PCBHide this!Advertise here!
lm3886 single sided pcb ryan750 Chip Amps 56 27th May 2015 02:35 AM
My tiny single sided LM3886 PCB layout. :) Russ White Chip Amps 74 14th September 2008 06:53 PM
pa100 pcb single sided layout lm3886 dgaxeman Chip Amps 6 24th May 2006 01:45 AM
Copyright ©1999-2017 diyAudio
