Old 26th September 2005, 06:15 PM   #1
Default YAY - finally finished my first gainclone and cases - pics too :)
Having been inspired by some of the superb craftsmanship I have seen on these pages, I have recased my amp and tried to make it look nice
The amp lives in a 19" 1U ex network switch case and the PSU lives in a 19" 2U case from Maplins (which is very poor quality for £40 BTW!!! - that'll be replaced sometime... Maybe I'll make a case from scratch if I feel brave
Anyway - thanks to those who have designed and produced the kits and to those who have inspired me to make it look nice (IMO) too.
Old 26th September 2005, 06:17 PM   #2
Default Pic 2
Old 26th September 2005, 06:21 PM   #3
Default Pic 3
I have used the same wood as I'm using for my speaker baffles so it should make a nice set.
I got a 1/2 inch ally bar and milled out places for the chips with a router - it was dead easy TBH but the bit suffered slightly.
The heatsinks are glued at the edges with epoxy and have heat sink grease in the middle - this has always worked fine for stuff I have done with pooters and is an easy way of attaching them.
I still have a bit ot tidying up to do but it's about done
Old 26th September 2005, 06:42 PM   #4
Good job. Very handsome case. Have any pictures of the inside of the power supply?
Old 26th September 2005, 06:44 PM   #5
VT67 is online now VT67  Belgium
VT67's Avatar
Consider yourself one of the craftsman. Very nice job!
Cheers
Old 26th September 2005, 06:59 PM   #6
Kind words indeed. Thank you both
Here is a pic of one side of the power supply.
Don't tell anyone but I haven't actually bolted the cap and snubber boards down yet I'm waiting for spacers to arrive. They are insulated on the back with cork sheets though. I'll have that done this weekend I hope.
The cap bit is from the carlosfm cap and snubber diagram from the Decibel Dungeon site.
I have used knitted copper wire tube on the mains leads and the transformer is a 500va shielded unit.
Old 26th September 2005, 07:17 PM   #7
RCBandwidth's Avatar
Thumbs up Very Nice
Quickshift.. that does look fantastic....I saved the pics for future reference..Bob C.
Old 26th September 2005, 07:30 PM   #8
Cor, thank you Bob.
Old 26th September 2005, 09:28 PM   #9
Is that for shielding?. If so how well does it work.
Old 26th September 2005, 10:10 PM   #10
Yes, that was the idea.
I don't know if it'll make any difference in this application TBH, I know that it's possible to shield electronic equipment from electronic surveillance by placing it in a cage made of knitted copper wire because it blocks EMR (faraday cage)
I wanted to try to reduce sources of RFI / EMI / EMR and all that stuff as much as possible and since the tube is only £1.25 per meter, I thought I would give it a go.
I don't think anyone else does this and I haven't tested it without the tube but it can't hurt I guess.
The amp is totally silent but other peoples are too and they haven't used tube.
Finally finished my amp! bikedude Chip Amps 16 18th June 2006 06:08 AM
pics of finished "industrial gainclone" cowanrg Chip Amps 0 28th June 2005 06:24 AM
*pics* parallel gainclone finished rwaudio Chip Amps 10 3rd November 2004 10:59 PM
Focal Utopia bookshelf /w pics - Finally, I finished something! SpeakerNut Multi-Way 7 23rd September 2004 12:43 AM
Page generated in 0.12985 seconds (65.68% PHP - 34.32% MySQL) with 11 queries
