tda 7293 and tda 7294 help
pcb
hi sagar
........it is the same ckt which i build,pcb also similiar. But i dont have that amp now.It would have been changed many hands now...:)
Yesterday i transfered the toner to the pcb and it was great transfer and tonight i m going to etch it. I m in search of a suitable plastic tub for etching process.Now i use a small plastic "dabba" used to keep buiscuits and namkeen...:D and use water heater (used for acquariums) I think u too use that.
any suggestions
regrds
aman
hi aman,
the transfer was supposed to be perfect(after following my guidelines:D).i suppose u followed all.
i have a plastic tub(mini rectangular box) 4 etching.
i liked your idea of mini heater rod:)
chemical,i suppose u will use anhydrous fecl3(with hcl if ok ok traces but without if pcb has very fine traces).
i would love to see the pcb of yours:devilr: .
pcb
hi sagarbhai,
yes,i followed ur guidlines strictly......:D thanks,hats off to u....:)
i use anhydrous ferric chloride from lr mkt, Rs 75/ half kg.I never use hcl,dangerous:eek: . with fecl3,heater rod and proper amnt of water it doesnt take more than 20 minutes.
I have populated that pcb 80%,rest i will do today after matching transistors.
I dont have camera/phone to show u the karishma like pcb....:bawling: :bawling:
but some day i will show the pcbs:)
aman
OH MY GOD.. PEOPLE of my location talking about the same ic as i wanted to know.. but i think you people dont logon.. if you do, i would love to know about 7294 amps.. of if any other you have made nowadays.. you are right.. my friend too made 7294 it burned without any output in 5 min... can you both help please?
Some like it , some don't care for it and some hate it as they seem to explode unpredictably when they used it. But yes it appears to be more touchy than say LM3886.
Don't ask for more posts on these . Use the 'search' button and chip name and you will get quite a LOT of threads on them. Read them all to get to grips with what people have to say about them. Then you could follow some construction threads also on this forum and make your own chip amp.
You might have noticed that you are some 5 years late on this thread ! :cool:
ofcourse i know i have bumped quite late that is why i have written if i am late by the way i have seen many chips and amps.. but right now i am still confused... there is a huge market in delhi but i donot know what parts are already available here and what not.. the place is like 25 km from my place(and no metro) so before i do unnecessary running around.. i'd rather take someones advice on making a good reliable amp
The 7294 is a fine IC but it has chances to be DOA. I built three amps using this IC. The 1st one i had some trouble with till i figured out that Vmute and Vstby have to go to the POSITIVE rail to turn on the amp. 4 years ago there was an error in the datasheet and they were referenced to the negative rail. Then it worked fine.
The 3rd one didn't go out of standby although everything was wired properly. If i would disconnect one of the power rails the amp would start (with a horribly distorted sound of course). I bought a new chip and dropped it into the same board - the amp powered up and still works to this day (3 years).
