| Chip Amps Amplifiers based on integrated circuits |
hello everyone,
by reason that smt ic is very common around world,I am going to make some adapter boards for myself.I wonder if anyone want them?If there are enough interest,I can make a group offer. I am not interested in making 8 pins smt to pdip adapter,because it is easy to resolve by diyer. here is my idea: 1,SSOP 28 pins to PDIP adapter,it is very generic(example,TI's dac chips,buffer ic). 2,QRP 48 pins expanding adapter(example,qs7785) any comment are welcome Zang |
#2 |
Hi Digi01,
Was hoping for some 14pin adaptors like the Brown Dog 050101. So I could do a TL074 upgrade that seem to be in lots of places such as my active crossover. Maybe as you do work on the project you might be able to offer a board mix with 8pin 14pin 28pin Soic to dip converters. Like a rescue kit for buyers of surface mount components who still have dip board. Just break off the ones you need to do the job. Six of each on each board. End user does the connecter pins. Good luck with whatever you decide to do. AnthonyPT |
#3 |
Try digikey , they sell some smd to dip/sip adapters.
SOIC to DIP for example , from Aries Electronics. Better to search with their printed catalog. Vitaly |
#4 |
to Vidalgo,
I have search digikey and the other resources,there are only photo boards but no adapter boards.Brown Dogs is a bit expensive for diy hobby. to AnthonyPT, thank you for your suggestion,I am planing the rescue kit now.and I have find a kind of golden plated pin at local,I will show you afternoon. Zang |
#5 |
Hi Digi01
As you say; a lot of these commercial adaptors are inclined to be expensive. Cimmaron and Soundlabs group both have good info and pictures of what is available. http://www.soundlabsgroup.com.au/c/B...Brown+Dog.html http://cimarrontechnology.com/index.asp http://www.cimarrontechnology.com/pdf/bdfootprints.pdf regards AnthonyPT |
#6 |
here is a roughly idea.the rescue board(kit) include:
2 pcs of SO14 to 14-pin DIP adapter, 2 pcs of SO28 to 28-pin DIP adapter, 3 pcs of SO8 to 8-pin DIP adapter. I have ask for local manufacturer,the price is around $4USD per kit. Zang |
#7 |
Hi Digi01
I have just been thinking about some other options. Adaptors for those using OPA627s who want to use them in a dual or quad application. So either all surface to dip or maybe in a duo dip to dip configuration. With bypass caps on board for the power? Sounds good that you have found some gold pins. regards AnthonyPT |
#8 |
P.S.
I have find this kind of pin for the adapter board. |
#9 | |
the attached photo show my idea,the left is 2 single so8 to dual dip8 adapter,the right is 2 single dip to dual dip8 adapter. rgds Zang |
#10 |
Electrons are yellow and more is better!
Zang, I'll adwise you to increase the traces a bit, 20-30 mils and add decoupling caps, 0805 types for the SO08->DIL08 adapter.
/Per-Anders (my first name) or P-A as my friends call me |
| Checking for interest in Conrad HS GB (USA ONLY) | Renron | Pass Labs | 37 | 22nd August 2009 01:37 AM |
| OPA 627/637/634/2132/2227 PDIP/SOIC + adapters | maxw | Swap Meet | 0 | 22nd November 2008 04:42 AM |
| Any Digital PLL Chip in PDIP/DIP pack..? | xitronics | Digital Source | 5 | 24th October 2006 12:04 PM |
| Smd -VS- Pdip,which one is the best choice? | digi01 | Digital Source | 2 | 23rd May 2005 08:41 AM |
| WTB: Crystal CS4390 - PDIP pinout !!! | ghg | Swap Meet | 2 | 7th November 2004 08:51 PM |
| Page generated in 0.14860 seconds (61.73% PHP - 38.27% MySQL) with 11 queries |
