| Chip Amps Amplifiers based on integrated circuits |
#1 | |
Dear all,
It's been a loong time ago that my analyzer was fired up last. This, and the fact that I got named in some recent thread flames, gave me the idea that I might as well serve some experimental basis to the discussions.. ))So I assambled, as usual, several experimental bypass configurations, and measured their impedance developing across a given frequency range. Basically, I would like to compare two configurations: The latest [according to my knowledge] "snnuberisierts" bypass arrangement a' la Carlosfm, as it is described in in this post The other one is the simple [classic] 10000 uF//220uF// 100nF bypass arrangement applied in the MY_ref project of Mauro Penasa. Though I could formulate this last statement also like this: "as it was suggested by Carlosfm half a year ago." As it can be seen from the previous, I would rather leave alone for a moment the ubiquitous "snubber" problem, that is, the reservoir caps & snubber part. About that a lot was told and measured earlier on. And, as I 've already stated, it does not have a measurable influence on the local bypass impedance [on the amplifier pins]. Which statement does not imply that it could not have an effect in other ways. So, what I would only test & compare here is this statement of Carlos: Quote:
The snubber cap is 2,4nF, because it is that what I had small. The 100 nF is the smallest possible 100V mylar cap. The resistor is as described, 0.1W/1R. The 3,3uF I had left out for a moment. There is a 4.700 uF reservoir cap connected, in some distance, to simulate reality. |
#2 |
Here it is the classic setup:
4700 uF // 100 uF // 100nF Here I used 100 uF instead of the 220 uF, about this later on. The 100nF is the same as before. |
#3 |
Banned
Fire that network analyzer up, bub! At least one of us is interested.
Jocko |
#4 |
Go go go, got a bag full of capacitors and a brand new transformer ... will be watching this corner..!
#5 |
Now, I would like to take a pass backwards, and show a comparison between two setup:
The [highlighted] Trace 1 shows : 4700uF//2200uF(local)//100nF The dimmer Trace 2 shows: 4700uF // 100uF (local)// 100nF The second setup is the classic. It provides a reasonably balanced and low impedance reaching up to ~2 MHz, then peaks at 3.5 MHz, then we can see the beneficial effect of the small 100nF bypass cap extending up to ~ 40-60 MHz. As it can be seen, changing the 100uF for 2200 has lowered the ESR value below 1MHz, and has emphatised the impedance peaking at 3.5 MHz, as it was expectable. [10dB difference] |
#6 |
Hey, thanks & nice to see You
![]() So, now I would insert the "snubber" Trace 1 is highlighted & fully "snubberisiert": 4700uF // 2200uF // 100nF // .1ohm+2.4nF Trace 2 is there for comparison, and is the classic setup. Well, as I had suspected, we introduced some more ringing.. |
#7 |
Ok, but there is one more thing to check: This was not yet the originally suggested, full setup: that one includes the 3,3uF across the floor.. that is, the supply pins.
So, I built the whole thing, two times 2200 uF //100nF, one piece of an MKT 1.5 uF /63 V across [I had this, reasonably small] and I am peeking into this assymmetrically, from the point of view of the, let's say, positive supply pin: [versus ground] |
#8 |
And here it is the corresponding response:
#9 |
Just making a marker to get email notification of new posts
Good work!! Mick |
#10 |
Is a snubber circuit designed for each chip or each channel? Let say I am using the calculation by Carlos and I am using the PSU for the XGC (which uses 2 chip amps per channel), do I need to have separate snubber circuits for each chip? If so, how will the calculation (capacitor values, etc) be affected?
| Meaning of an output's "load impedance"? | pedrito | Analog Line Level | 3 | 30th June 2009 07:58 AM |
| 15" Drivers, Part 2: Mathcad sims versus SPL graphs | cuibono | Full Range | 21 | 5th November 2007 10:40 PM |
| need list of "standard" values such as impedance | keantoken | Everything Else | 3 | 30th August 2006 04:40 AM |
| Define "snubber" | kneadle | Chip Amps | 5 | 31st December 2004 06:12 PM |
| Page generated in 0.22108 seconds (43.08% PHP - 56.92% MySQL) with 11 queries |
