Old 17th September 2005, 08:39 PM   #1
VEC7OR is offline VEC7OR  Lithuania
VEC7OR's Avatar
Send a message via Skype™ to VEC7OR
Default Coping with NE5532D output DC offset
I've designed and assembled a headphone amplifier based on NE5532D (http://images.bite.lt/banga/files/cl...ac13923b17.png schematics, http://images.bite.lt/banga/files/cl...ac189633db.jpg PCB, http://images.bite.lt/banga/files/cl...ac1d14c818.jpg insides, http://images.bite.lt/banga/files/cl...ac1e4eedd1.jpg front)
On each output it has 0.121V DC offset, I dont think it does alot of harm to my 64ohm headphones because power sink due to dc offset is just ~220uW, but it somewhat bugs me, how can I rid of it ?
P.S. As for the amp itself I really like the sound - its dead quiet when there is no signal and transparent when it is .
Profanity took a very interesting form in Russia where there exists a language of sorts, most of its words based on four basic profane roots - nouns p...is, wh.0.e, c..t and verb f..k. It is possible to sensibly communicate using just these four basic roots.
Old 17th September 2005, 08:59 PM   #2
Electrons are yellow and more is better!
peranders's Avatar
You have made one or two mistakes.
The offset (taken from my head) is 1-4 mV times your gain, 11 in your case (a bit much gain?) this gives you approx. 40-50 mV. The reason why you have so much additional offset is the 100 k at the input. If you want to minimize the offset you should insert a capacitor between 10 k and ground. This will create an offset of 4-10 mV only. The trick is that each input of the opamp should "see" the same DC resistance.
/Per-Anders (my first name) or P-A as my friends call me
Old 17th September 2005, 09:12 PM   #3
VEC7OR's Avatar
Or I just remove 100k resistor ?
Old 17th September 2005, 10:00 PM   #4
mzzj is offline mzzj  Finland
Noo!
you have to aim for equal (dc) resistances in both inputs, if you remove that 100k then you end up with far worse situation as then its 10k||100k(~9k) for -input and infinite for + input.
Old 18th September 2005, 07:18 AM   #5
peranders's Avatar
No, because every opamp MUST have a DC path somewhere in order to work. The NE5532 has NPN transistors at the input and those transistors must get base current from somewhere.
Old 21st September 2005, 01:31 PM   #6
VEC7OR's Avatar
I think I got it now, I should replace 100k resistor in input to 9k resistor, that way both inputs will see the ground through 10k resistance.
Output DC offset. nigelwright7557 Solid State 3 20th April 2009 01:14 PM
Coping with amp box heat (not heatsink sizing) cfcubed Pass Labs 5 23rd July 2008 04:59 PM
DC offset at analog output LuisMCP Digital Source 0 23rd September 2007 07:56 PM
How much output offset voltage is too much? tubetvr Solid State 14 1st July 2004 10:47 PM
Ne5532d Soic R-16 audiodoc Parts 0 7th December 2002 07:13 PM
Page generated in 0.10987 seconds (68.80% PHP - 31.20% MySQL) with 10 queries
