| Chip Amps Amplifiers based on integrated circuits |
Moderators,
Would you please move the BasicStamp postings from the “High End Pre Group Design Invitation” thread over to this thread? Fear that suggestion of alternative micro-controller was un-welcome and would like to start fresh with a new thread for those interested. Thank you -ALBQ |
#2 |
Why don't you just summarize it for us and give a link to the old thread. Those who are interested can follow it up.
Paul p.s. I want an RF remote. So, does ''Remote Control for Everyone" include me? |
#3 |
Summary,
Suggestion was to build a remote controlled preamplifier using a Basic microcontroller such as a BasicStamp, BasicAtom or BasicX microcontroller. Although slower than a PIC or Ubicom, the controller can be programmed in basic using free downloadable software. The advantage of such a solution for the DIY community is that it takes minimal software knowledge to get it working and, can be easily modified at by the end user. This means that once a basic design is developed, people are free to build upon it. Oh, on your question, was thinking more along the lines of IR remote but, hey - its for everyone so, why not Cheers -ALBQ
#4 |
BS2 code and specifications for above:
BS2 source code: http://mywebpages.comcast.net/gilles...me-Encoder.bs2 Specifications: * BasicStamp2 micro (will migrate to BasicAtom) * PGA2310PA - digital volume control (256 step) * IR - function (power, volume, mute & IO control) * LCD display - on/off greeting, volume setting, mute, function * Rotary Encoder volume control * +/-9V Analog PS w/switching for when unit is off * +5V-9V Digital power - onboard filter network to wallwort Still to go: - Migrate code to BasicAtom - more speed, power & memory - Add switch inputs - for manual control (74C922) - Write code for balance control via rotary encoder (mult func) - Change LCD for VFD - Final design of power supplies - Draw and etch PCBs - Put it in a box |
#5 |
Banned
here is mine.
#6 | |
![]() So this is a neat programmable switchbox and volume control, not an active pre-amp, right? Could I add an active preamp into the mix without too much trouble? Any idea on what the costs are approximately? Regards, Michael
My AudioProjects Gallery |
#7 |
Michael,
Somewhat - with a PGA2310 you could go either way. Leave it as is, would not exactly call it passive or add a stage of your choosing. Total cost as you see it is around $150, maybe a little less. My earlier design: http://mywebpages.comcast.net/gilles...U7-Preamp.html
#8 |
jleaman
I was wondering that would u be kind enough to let us know the source of this PCB, and if i m not wrong its based on AT89S8252 an 8051 based AVR? I too have got almost the same board.... |
#9 |
Banned
Im going to be selling these as kit's the pcb comes from a friend in china
#10 |
Banned
I have many idea's of my own to build a better pre-amp.. Does any one want to work on this and put all there ideas into one pot and make a good pre-amp ?
Id also like to use this LCD.. |
| Remote volume control for existing remote? | theAnonymous1 | Parts | 7 | 6th August 2007 08:22 AM |
| The remote control paratactic volume control | audio-gd | Solid State | 33 | 7th June 2007 11:16 PM |
| remote control motorised control for volume pot/knob | CharlesY | Parts | 0 | 25th July 2005 11:12 AM |
| Remote control | nlinus | Solid State | 8 | 23rd February 2005 11:35 AM |
| Page generated in 0.13379 seconds (67.49% PHP - 32.51% MySQL) with 11 queries |
