| Chip Amps Amplifiers based on integrated circuits |
Hey, im looking to start building a full size amp, but I'm unsure of which IC to base it on. Any suggestions/schematics you guys have would be really helpful.
#2 |
LM3875 BPA.
Very full sized for Chip amp. Harry |
#3 |
Thanks alot, I'll check it out and see if I can find some more info and specs.
#4 |
Try LM3886 or LM4780 too.
#5 |
Any of the National Chips are good. I think the LM4780 is already 2 channels and also has a PCB layout in the datasheet.
Can't get easier |
#6 |
It might be less work to use two lm3886 instead of one lm4780. The pin and the space needed for external parts wont be as tight.
#7 |
This site has inverted schematics. It should be helpful.
http://www.freewebs.com/matttcatttweb/audio.htm |
| full range box size when using a subwoofer | pforeman | Full Range | 27 | 22nd March 2009 10:27 AM |
| Simple, Inexpensive, yet Decent Full Range/Single Driver system? | dsavitsk | Full Range | 11 | 16th August 2006 10:40 PM |
| WTB: full size pedalboard in Lower Mainland | Nixie | Swap Meet | 2 | 6th February 2006 01:15 PM |
| What are some decent drivers for a small/mid size center channel speaker (1 mid,1 tw) | kehi | Multi-Way | 24 | 21st December 2003 08:10 AM |
| Page generated in 0.10066 seconds (64.55% PHP - 35.45% MySQL) with 10 queries |
