| Chip Amps Amplifiers based on integrated circuits |
I'm looking to make a nice sound boost to my car audio system but I need to know a good amp choice to do it with. I'm only using a single supply by using a 120w DC-DC converter to up my car battery to 24v. So I will only have one positive voltage. I've been working with the LM4752 which is a very nice single supply stereo amp but it only outputs 11w per channel and I'm hoping to get at least double that. I tried hooking up the LM1875 in Single Supply but it only gave me about 9w max. Can anyone recommend a good powerful single supply amp?
-Segasonicfan |
#2 |
How much power are you looking for, and into what impedance?
The most you'll get out of a single 24v supply without bridging is around 6W into 8Ohms 12W into 4Ohms or 24W into 2Ohms Assuming an amp with around 2.2v of rail loss. |
#3 |
I'm using 4ohms and I'm looking for the most power I can get (25w+). 12w is really lame I guess my best bet is to just bridge the LM4752 :/
-Segasonicfan |
#4 |
look at the data sheet of TDA7386, its says 40wattx4 at 13.2, i ve used this chip and it is really good
#5 |
I believe you are incorrect, abidr. Looking at the datasheet, on the very first page it is stated:
4 x 24W/4W @13.2V, 1KHz, 10% THD A very poor rating, so looking further down the datasheet, to page 3 it is stated that at 13.2V you have a typical output power available of 18W at 13.2V with 0.8%THD measured at 1kHz. On page 6 there are a couple graphs of distortion measured at 14.4V supply. Quite poor quality if you ask me, but I guess it's what to be expected of a car cdplayer amplifier chip.
The power of Science compels you! |
#6 |
diyAudio Moderator Emeritus
if you aren't afraid of class d amps then have a look at this:
http://www.41hz.com/Forums/topic.asp?TOPIC_ID=129 |
#7 |
Why don't you use Philips IC TDA1562Q, which works on 14V supply voltage and gives about 70W of power, because, it's a class-H amplifier. Simple schematic ;-)
#8 |
tda1562 can pump in the rated max for only few secs depending on the power caps that u use at its power rails.
i have a four channel amp driving six speakers in my car(4 ohm each). tda1554q is great.22w/channel,2channels and very simple to make.works of +12v!! tda8563 can drive down to 2 ohms with 40w/channels,2 channels,very very simple to build.it drives 4 speakers in car.runs off +12v!! so both can be connectecd directly to car batteries.so total power at disposal for me is 120w rms. so use of these highly recomended(people ask me bout good quality system in my car!).whats more,i use my sony discman as i/p for both without any preamp and the i/p is sufficient for the amp. both ics stereo so choice with u |
#9 |
oh!i forgot.try tda7560 and another one named similarly,might be 7563.the rated power o/p is good.both for car and run from car battery i havent used them bec very costly from my source of semiconductors.
#10 |
tda8563 is quite nice, I have also used it in a amp. Phillips have discontinued the TDA1554, TDA1553 and the TDA1558. Try the TA8210, I think Toshiba makes them, they also have a higher power version both of them work from 13.3v, they are also quite common in some small car amplifiers and don't sound too bad either...
| help with single supply for two EQ/preamps | lassoharp | Power Supplies | 3 | 9th July 2009 03:24 PM |
| Is a single 3886 powerful enough to drive SS 18w-4531 ? | 100db | Chip Amps | 10 | 13th October 2007 04:02 PM |
| printer single supply becoming split supply? | facundonu | Power Supplies | 2 | 16th November 2006 06:09 PM |
| looking for powerful Single Ended diagram. | flyingman | Tubes / Valves | 28 | 10th February 2005 02:46 AM |
| How to split a single supply | cm961 | Parts | 13 | 9th October 2004 03:17 PM |
| Page generated in 0.13374 seconds (66.87% PHP - 33.13% MySQL) with 10 queries |
