Old 7th September 2005, 10:42 AM   #1
mobyd is offline mobyd  New Zealand
mobyd's Avatar
Default LM3886 pathology, TDA7293 better?
I fix pro audio gear for a crust, and one of the brands I fix is JBL.
JBL make a powered speaker called an EON, which uses an LM3886 to drive the compression driver tweeter. Occasionally these things go bang and almost invariably take the diaphragm out as collateral damage ($$$$) (dias don't like -38 volts DC).
I use the 3886 myself by the bucket in installation amps (museums etc) and find them pretty trouble free unless I run them close to the max voltage limit (like JBL does). Would I be safe in assuming that it is overvoltage that shags them or is there something else (like parisitic oscillation) that lays them low.
Recently had one of the latest eons in for repair and noticed that JBL had switched over to TDA7293s for the tweet - ahh good, I thought- higher voltage rating, less bang potential - but alas no, the TDA had blown to bits (literally) and taken out the dia, just like old times. Interestingly, I've never seen a single catastrophic failure in the LF amps, which are discrete design.
M
Old 7th September 2005, 12:21 PM   #2
mwmkravchenko's Avatar
Default The chip is pretty tough
I always thought that the chip would go into protection mode. I have learned something new here. Definitly sounds like a over voltage failure.
Mark
Mark
Old 7th September 2005, 02:35 PM   #3
Russ White's Avatar
Send a message via Yahoo to Russ White
Actually the problem described sounds much more like a faulty circuit implementation than any problem with the chip itself. But there is no way to know without a schematic and other details.
Less pulp more juice Twisted Pear Audio.
Old 2nd November 2005, 07:49 AM   #4
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
Have a look here for the schematic.
The tweeter not allways go's, only two of the tree times.
http://www.jblproservice.com/navigat...%20Series.html
Cheers, Zilog
Old 2nd November 2005, 08:08 AM   #5
sagarverma's Avatar
tda7293 is delicate one.(its the only chip that smoked out in a ckt made by me).its failure is not a surprising for me ,its great one(better sound and clarity than lm) but it needs extreme care too.
i wonder how lm 3886 goes wrong.its a very tough one.one i built an year ago still workin inspite of abusive use.must be bec(surely) of high voltage.. + - 35v is at the edge of safety envelope for it. + -38v is way too high.mine operates at conservative + - 30 v
lets see what comes out of this thread
lm3886 tda7293 tda1514 rulezzz Chip Amps 21 22nd September 2011 11:45 AM
Tda7293 or LM3886 Modular Application Dr007 Chip Amps 3 17th November 2006 06:51 PM
Tda7293 lasstss Chip Amps 2 14th December 2004 04:36 AM
Where can I get a TDA7293??? mfish0305 Solid State 2 18th January 2004 03:19 AM
Tda7293 chengtaw Solid State 0 18th April 2002 01:19 PM
Page generated in 0.11290 seconds (64.80% PHP - 35.20% MySQL) with 10 queries
