Old 20th August 2005, 08:21 PM   #1
12 Cents's Avatar
Default Another ChipAmp running
Hello,
since I found this forum I wanted post some "Hello post" with a project worth showing. So please take this as a kind of introduction post from me, ok ?
The amplifier is a LM3886 in a datasheet-like fashion like proposed by Mr. SL. I left out Ci, 17mV DC offset at the outputs with a source attached. Without, ~70mV. It worked (almost) from the start and sounds just good.
My thanks go to the designers and manufacturers of these great little chips.
theduke
Old 20th August 2005, 09:08 PM   #2
12 Cents's Avatar
Also my true thanks go out to the makers and all the contributors of this forum. This is great.
Old 21st August 2005, 07:33 PM   #3
Mick_F is offline Mick_F  Germany
It looks as if you have some quite big caps in the PS. Do you have some snubbers close to the supply bypassing caps of the amp to account for this? If not, there might be some serious improvement possible here.
Mick
Old 21st August 2005, 08:15 PM   #4
12 Cents's Avatar
Yes, I cloned Carlos' snubbered filter section with 2x10mF per rail. Slight problem: I measure 100mV less voltage on the negative rail (after the filter R's)
theduke
Mick, I like your photography
Old 22nd August 2005, 09:41 AM   #5
Did you check the values of all capacitors and resistors involved? A difference of 100mV is less than one percent of the rail voltages and might be explained within the parts' tolerances.
Old 22nd August 2005, 05:15 PM   #6
12 Cents's Avatar
It must be the bleeders, which act as virtual ground creators in my case too. Should the circuit ground be earthed?
Old 24th August 2005, 05:21 AM   #7
12 Cents's Avatar
Feedback resistor, Mute resistor
Old 24th August 2005, 08:37 AM   #8
Thats a good idea to put the mute resistor directly onto the pins.
Btw. Where do you buy your parts in Germany?
Mick
Old 24th August 2005, 11:07 AM   #9
12 Cents's Avatar
Bei Reichelt
The LM's are from a forum guy, brunoravera...
Old 24th August 2005, 01:26 PM   #10
Send a message via Skype™ to slackman
Hi Mick,
drop me a line if you're interested in LM-chips. I still have some samples stocked.
If you pay the transport fee, National will also send samples to you (I think). The only point is you must create an account and you should have a credit card...
My first sets (LM4780) i bought from Peter Daniel , really nice work and price is ok.
Heho Elektronik also has the LM3886 in T and TF for about 9,- Euros and some other LMs too (no 4780... ).
Michael
PS: Great photos, I like this style...
F2 running hot(how hot is hot?) Aron Pass Labs 10 13th February 2009 03:42 PM
What advantages running ported midbass if you are running a sub? mitchyz250f Multi-Way 3 20th May 2008 02:34 PM
Running-in the UCD 180... ptwining Class D 10 12th August 2006 05:19 AM
New Ono up and running Ed Robinson Pass Labs 13 14th June 2003 06:45 PM
p3a up and running :) Jean Solid State 10 1st December 2002 02:07 AM
Page generated in 0.10997 seconds (73.62% PHP - 26.38% MySQL) with 11 queries
