Old 14th August 2005, 07:47 PM   #11
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Tighter tolerances have no effect on DC offset or quality of the sound. They will only influence the matching of both channels (of gain for instance).
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 14th August 2005, 08:01 PM   #12
OK, cheers.
That's saved me a few quid.
Old 14th August 2005, 08:26 PM   #13
Vikash is offline Vikash  United Kingdom
diyAudio Moderator Emeritus
Vikash's Avatar
Hi quickshift, offset on one of my amps is 120mv and I have no real issue with that.
To quote good ol' Carlos:
To avoid high values of DC-offset, sometimes very different from channel to channel, you need to use the Ci caps (Look at Fig. 1 on the LM3875 datasheet).
Good electrolythics bypassed with quality poly 0.1uf caps will bring DC-offset to a couple of mv, without affecting the sound.
more here: http://www.diyaudio.com/forums/showt...773#post469773
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.)
Old 14th August 2005, 08:37 PM   #14
Hiya,
Ah! Now I know where I know your name from.
Excellent, thank you.
Sounds like a plan, I'll have a go.
Q.
Old 14th August 2005, 09:01 PM   #15
Electrons are yellow and more is better!
peranders's Avatar
Originally posted by quickshift
I have measured it with the inputs shorted, the high side reads 57.6mV and the low side reads 13.1mV. If it's down to the chip I'll get a replacement, would it also be worth getting premium components with tighter tolerances?
In other words you have 1.8 mV and 0.41mV in input offset voltage (pretty good) but you have also a current flowing into the non-inverting input of the amp (see datasheet about input bias current). It's this current which adds on the extra offset.
/Per-Anders (my first name) or P-A as my friends call me
Old 14th August 2005, 09:35 PM   #16
Thank you.
OK, that's not so bad then.
I'll put the fire extinguisher away now.
Actually, joking aside, such is my faith in my abilities with electronics that the first time I switched the amp on I used a bit of wood at arms length while holding a fire extinguisher across my face in case it caught fire or exploded. Mind you I made the loom for my track bike but that's just wires so it's easy.
Thank goodness people have had the time, skill and good sense to make kits so people like me without the ability to create an amp from scratch can also enjoy them.
Three cheers for the kit suppliers
Old 15th August 2005, 01:42 PM   #17
Hello again.
Right, I have looked at the diagram, it's very nice but I don't understand it.
I have looked up bypass caps and it says connect the cap between the power and the main ground - that seems simple enough in itself.
I'm assuming I need to buy 0.1 uF poly caps and 22uF electrolytic caps - one per amp board but what do I do with them?
I have the rev 3 boards and haven't implemented the zobel.
Sorry for not really understanding much about all this stuff yet.
Old 23rd August 2005, 01:43 PM   #18
Default Sorted. :)
Right, I have worked out where to put the 22uF caps - I unsoldered ground side end of R3 (681 ohm) and lifted it from the board a bit, popped the - of the cap in the hole and then soldered the free end of R3 to the + side of the cap.
Results...
DC offset is now 1.7, 0.5, 0.5, and 0.5 YAY!!!!
I did 1 ch first and had a listen for a bit, adding the cap has further smoothed the sound, there was a tiny touch of grittiness or edge on the channel without the cap compared to the channel with the cap, I didn't notice it before but when switching between l + R on the preamp it was obvious. It's certainly made an improvement to the sound without any negative side effects. I'm assuming this is because the speakers have to work against the DC as it will slightly push the cones and offer more physical resistance in one direction of travel.
Many thanks for the info and help everyone.
I have also made the caps and snubber section of the carlosfm PSU (using a diagram!) from the decibel dungeon site (excellent BTW) and will add that between the PSU and amp boards next.
AudioSector LM3875 dual mono premium kit. nodiak Swap Meet 1 16th October 2007 06:38 PM
LM3875 Dual mono amp Whitebread Chip Amps 5 26th June 2006 08:16 AM
Brian GT LM3875 dual-mono chipamp kit darkmoebius Swap Meet 5 20th July 2005 07:42 AM
ChiAmp.com LM3875 Dual Mono Amp Kit Firebottle Swap Meet 1 28th January 2005 08:29 AM
FS: BrianGT gainclone kit. LM3875 Dual Mono Kit mattjk Swap Meet 3 16th November 2004 01:24 AM
Page generated in 0.12295 seconds (81.70% PHP - 18.30% MySQL) with 10 queries
