Audio sector gainclone.
Old 11th April 2008, 01:46 AM   #31
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
Default Re: Voltage at my speaker terminals?
Originally posted by bsmif
Just wired up my first gainclone (one of Peter's 3875 kits). For some reason the negative voltage is coming off the positive connections of the powersupply board and vice versa. It was hooked p this way briefly before I turned it off, tested the leads and switched them. (seemed easier than flipping the diodes or trying to figure out what I did wrong on the PSU. SO Now one channel works fine while the other has -27 volts at the speaker terminals. Also has -1.2V at the input. Any idea what I did wrong? What I am likely to have blown out by having the wrong voltage hooked up briefly?
That is the elegant "rows" design for rectifier, so start at V+ and arrange the diodes so that the "|" faces V+ for all of the diodes.
You can (should) test the rectifier board before connecting the amplfiers.
Here's a picture for reference of diode polarity:
(see attached photo)
Perhaps the next step is to double-check the transformer hookup.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 11th April 2008, 04:07 AM   #32
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Audio sector gainclone. Send a message via AIM to Peter Daniel
The diodes should be installed as in attached pic (the stripes mark the metal tabs):
To order kits contact me through forum mail.
Old 30th May 2010, 08:52 AM   #33
cdesign is offline cdesign  Netherlands
cdesign's Avatar
So, this one (post #6)
http://img244.imageshack.us/img244/4342/wiring1ra.jpg
is not correct?
Old 31st May 2010, 02:12 AM   #34
lanchile is offline lanchile  United States
lanchile's Avatar
is not correct?
Yes, I believe those diodes in that post are not correct.
Old 16th February 2013, 12:06 AM   #35
JonGain is offline JonGain  United States
JonGain's Avatar
that picture needs to be wiped from the internet........
Jon.........~~~_/)~~~
Old 16th February 2013, 01:32 AM   #36
lanchile's Avatar
yeah! those diodes were put the wrong way!!! There are black lines on the board that are the metal side of those diodes, as Peter explain in the post above.
Audio sector gainclone.Hide this!Advertise here!
audio sector- lm4780 kit richyrich212t Chip Amps 1 25th August 2007 10:14 PM
FS: Audio Sector DAC $180 sts9fan Swap Meet 2 8th June 2007 01:46 AM
Finished Audio Sector NOS DAC* vdi_nenna Digital Source 4 4th February 2007 05:49 PM
Help with Audio Sector NOS DAC vdi_nenna Digital Source 14 14th January 2007 03:31 AM
Audio-Sector discussion splitoff jleaman Everything Else 58 23rd March 2005 06:22 PM
