Audio sector gainclone. - Page 2 - diyAudio
Old 14th August 2005, 06:05 PM   #11
jackinnj's Avatar
Default Re: Re: Audio sector gainclone.
Originally posted by Peter Daniel
Zobel also changes tonal balance, and some people prefer it this way.
Boy, I would like to see that statement verified with a spectrum analyzer.
Old 14th August 2005, 06:07 PM   #12
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Default Re: Re: Re: Audio sector gainclone.
No fighting..
Old 14th August 2005, 06:09 PM   #13
jackinnj's Avatar
Default Re: Re: Re: Re: Audio sector gainclone.
Originally posted by jleaman
No fighting..
No empiricism either.
Old 14th August 2005, 06:12 PM   #14
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Me too
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 14th August 2005, 11:37 PM   #15
dome406 is offline dome406  United Kingdom
Sorry if this is a stupid question but is the Rf resistor the 22.1k resistor soldered between pin 3 and 8 of the lm3875 or is this another one, because I have soldered it below the the board if it is. The only reason I ask this is because I got 4 22.1k resistors and had none left by the time I got to the Rf one. and that would make sense.
And another quick question if you have time is what do the cz and rz capacitor and resistor do.
Sorry for all the questions I just want to understand all the options rather than just mess around with everthing and nothing work .
Thanks very much.
Old 15th August 2005, 01:38 AM   #16
If you soldered it below the board, then it's alright.
Cz and Rz are Zobel components and you can read about them here: I'm sorry, but the amp needs a zobel
As always, I leave the choice to use them, to you.
Zobel components are supplied with every Classic kit, they are supplied only if asked for, with a Premium version.
www.audiosector.com
Old 15th August 2005, 08:02 AM   #17
Here is a picture of the underside, what should I use to clean all the flux and stuff off it because you cant get rubbing alcohol in this country. Is meths ok or is it too oily.
http://img227.imageshack.us/img227/9276/dscf07960lj.jpg
Old 15th August 2005, 08:06 AM   #18
Electrons are yellow and more is better!
peranders's Avatar
Can't you get some burning alcohol or propanol?
You can also take a stuff brush short hair but soft, brush dry first then brush wet with plain water and dish detergent like "Yes". Rinse with water and blow it dry with compressed air or let it dry in 40-50 deg for an hour or so.
I use first propanol and then Yes and water. I dry with compressed air.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 15th August 2005, 08:51 AM   #19
Ok I will give it a go.
Old 15th August 2005, 01:19 PM   #20
Here's the preferred way to mount feedback resistor. Although it is intended for Caddock mostly, it should also work with regular resistors. There is a small hole right beside pin 8 for one resistor's end, the other end solders directly to pin 3 on the chip. This method eliminates the chip pins length (when mounted underneath) and allows shortes feedback loop, at the same time being easy to implement, without need for elaborate resistor pins bending.
www.audiosector.com
audio sector- lm4780 kit richyrich212t Chip Amps 1 25th August 2007 10:14 PM
FS: Audio Sector DAC $180 sts9fan Swap Meet 2 8th June 2007 01:46 AM
Finished Audio Sector NOS DAC* vdi_nenna Digital Source 4 4th February 2007 05:49 PM
Help with Audio Sector NOS DAC vdi_nenna Digital Source 14 14th January 2007 03:31 AM
Audio-Sector discussion splitoff jleaman Everything Else 58 23rd March 2005 06:22 PM
Copyright ©1999-2017 diyAudio
