Old 3rd August 2005, 06:48 PM   #1
Russ White's Avatar
Send a message via Yahoo to Russ White
Default Latest experiment... Inverting-NOT
Ok, this one is a little hard to follow at first. Borrowing from some ideas I have gotten from Mauro and others I have created a design that uses a LM3886 and a OPA2227 (dual low noise opamp) to create a non inverting amp, but the LM3886 is operated as inverting. Basically a double inversion with a buffer input.
The first part of the OPA2227 is simply a high input impedance buffer, which feeds the signal through the second gate in inverting mode, that signal is input to the LM3886 in inverting mode, so the final output is not inverted(or completely flipped, which ever you prefer).
Here is the schematic.
Sorry, its a mess.
Less pulp more juice Twisted Pear Audio.
Old 3rd August 2005, 06:49 PM   #2
Russ White's Avatar
Here is the PCB.....
Old 3rd August 2005, 06:52 PM   #3
Russ White's Avatar
It is all still very preliminary. I am just looking for some ideas on values and such. You will noticethe PCB is not finished (no mounting holes even).
Old 3rd August 2005, 07:05 PM   #4
VT67 is offline VT67  Belgium
VT67's Avatar
You really honour your signature, aren't you
Old 3rd August 2005, 07:08 PM   #5
Russ White's Avatar
Hey, its better than psychotherapy.
Old 3rd August 2005, 08:17 PM   #6
Banned
Why put a op-amp in the middle just to serve as an inverter??? They almost never sound good. I would rather leave it inverting, and flip the speaker leads.
OK.........you do need some sort of buffer to run it in the inverting mode, but I would not use an op-amp with unity gain.
Jocko
Old 3rd August 2005, 08:29 PM   #7
Russ White's Avatar
Jocko
You make some pretty aweful assumptions...
A good opamp makes an excellent buffer, and the purpose of the opamp is not "only" to invert the signal.
The worst assumption is about the sound. I have built an amp like this (but it was Maruo's design which is slightly different) and it sounds superb.
One of the reasons this works well is the very low output impedance of the opamp, as well as slew rate and other virtues.
Cheers!
Russ
Old 3rd August 2005, 08:50 PM   #8
question1.
what are R2, C7 for? i can only assume it is DC-offset related.
q2:
why do all inputs have resistors?
q3:
what reason did you have for the choice of resistors?
q4:
why not run the feedback path to the first opamp?
if only it could be used for good, not evil...
Old 3rd August 2005, 09:00 PM   #9
Russ White's Avatar
Originally posted by theChris
question1.
q2:
q3:
q4:
q1
Yes R2,C7 act to nullify DC.
q2 Well, partly to help set gain for some stages, but on the first stage it is to form a low pass filter to filter out RF.
q3 I was just using values I had used in the past for other applications. Some values I used just because they got me the gain I was looking for.
q4 The reason is the the first opamp gate is purely a buffer to aid the inverting opamp stage.
I am using techniques similar to the ones found here:
http://www.diyaudio.com/forums/showt...225#post622225
Looking over that thread may answer a lot of your questions.
Old 4th August 2005, 05:31 PM   #10
Russ White's Avatar
Default Almost ready to etch...
I have changed the regulators do to some great input from carlmart and others.
I also added the rest of the missing pieces. I think its ready to go.
The resistor at output can either be 10R 5W with a .7uH inductor wound around it, or .3R 7W.
Here is the current schematic (still a mess sorry).
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 12:37 PM
whats the difference between inverting and no inverting mikee55 Parts 1 7th January 2007 10:36 PM
Aleph Phase Inverting / non inverting macka Pass Labs 9 22nd February 2006 07:01 PM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 06:53 PM
Inverting/non-inverting Op-amp Inputs !!!help!!! IIR Solid State 17 11th May 2002 02:02 AM
Page generated in 0.14679 seconds (62.51% PHP - 37.49% MySQL) with 11 queries
