Old 1st August 2005, 01:05 AM   #1
kmj is offline kmj  Sweden
kmj's Avatar
Default PCB for simple OP-preamp
to keep it short, will this do for a pcb-layout? I have never made a pcb before but i had some time over and parts that were of no use at the moment
the ground from the pot is at the same place as the inputground.
Old 1st August 2005, 04:04 AM   #2
Hello kmj
Looks good I think, you could move your 0.1uF on the V+ rail I guess. Put it between the Output L/R resistors and move your Output ground hole a little bit.
Old 1st August 2005, 07:15 AM   #3
Roushon is offline Roushon  India
it might be a good idea to make and connect the input ground to the power ground by a thin track, otherwise distortion may get into the input signal.
S. Roushon
Old 1st August 2005, 07:31 PM   #4
kmj's Avatar
Roushon
So just make the rail between the 0,1uF MKP cap and the inputground thinner then.
tobias_svensk
Just move the cap to the other side of the electrolyte then.
(those yellow things next to the out R and out L text are two VERY big capacitors )
I'll have to test your advice, i put it together this afternoon and it works. However, i get a loud background buzz, like a bad radioreception.
Old 2nd August 2005, 09:39 AM   #5
make the whole vertical track on the left hand side of the pcb thin.
S. Roushon
Old 2nd August 2005, 06:30 PM   #6
kmj's Avatar
Will do.
The buzzing is still there and i stumbled on a strange problem.
It still works with the NE5532 op, buzz and all, but not with opa2604.
If i shut the pre down and change op the fuses melt. strange since the opa2604 only need about 5-6mA and the fuse is rated at 125mA-slow and the supply is a regulated 12V.
one shouldn't have any prblem with something as simple as this....
Old 8th August 2005, 09:07 PM   #7
veteran is offline veteran  Poland
veteran's Avatar
Several months ago I also designed pcb for single op-amp preamplifier I enclose several pictures. There is also dedicated symmetrical power supply based on LT317/337 regulators.
Simple audio solutions
blog.unisonus.com
Old 8th August 2005, 09:08 PM   #8
veteran's Avatar
Power supply pcb...
blog.unisonus.com
Old 8th August 2005, 09:10 PM   #9
veteran's Avatar
Bottom side of preamplifier pcb.
blog.unisonus.com
Old fashioned simple preamp PMA Analogue Source 19 14th August 2007 09:12 AM
simple preamp pxr5 Solid State 9 20th November 2004 07:29 PM
Simple discrete preamp OliverD Solid State 69 22nd July 2004 10:14 PM
Very Simple Preamp Christian Solid State 1 21st March 2002 09:50 PM
need simple preamp JoeBob Solid State 41 9th January 2002 06:06 AM
Page generated in 0.11523 seconds (70.45% PHP - 29.55% MySQL) with 11 queries
