| Chip Amps Amplifiers based on integrated circuits |
I designed this little PCB for those killer alpha pots you can get from Jaycar.
I have not tried it yet. Mostly I wanted the board to avoid having to solder wire directly to the tiny pot, but also because I wanted a place for a resistor on input since for even some of my unity gain headphone amps some of my soures are too hot. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#2 |
Can you change it to have input and output jumpers, rather than left and right jumpers? Oh, and some mounting holes?
Looks good. Thanks.
Twisted Pear Audio |
#3 | |
Absofreakinglutely.
#4 |
Ok, here its with one header for in, one for out.
#5 |
Are you using the double ganged pot for the input or 2 singles?
#6 | |
???? This is a double ganged pot yes.
#7 |
Right... sorry... I thought you were using an alpha double ganged log pot but all I see on jaycar is the double linears.
#8 |
#9 | |
Its not problem, I just didn't understand the question. ![]() Cheers! Here is an update:
#10 |
What about tightening up the layout a bit and adding mounting holes?
And we should start updating the wiki more, it seems a little out of date. Is there a diyaudio ftp somewhere for linking to stuff on the wiki? or should we link to the forums? I would use my host, but in 5 years you'll just see 404 not found errors. |
| Alpha Pots | AmpBuilder225 | Tubes / Valves | 3 | 21st March 2009 06:17 PM |
| knob with long end for alpha pots | PRNDL | Tubes / Valves | 3 | 14th January 2008 12:13 AM |
| Tiny, tiny DC-DC converter | jackinnj | Power Supplies | 1 | 28th June 2006 07:03 PM |
| Alps pots vs. TKD pots? TKD worth the extra$$? | G | Tubes / Valves | 11 | 17th August 2004 04:33 AM |
| any good tiny tiny tweeters? | THOR | Multi-Way | 18 | 28th June 2004 06:42 AM |
| Page generated in 0.15378 seconds (60.34% PHP - 39.66% MySQL) with 11 queries |
