| Chip Amps Amplifiers based on integrated circuits |
Well, I was beta tesing my newly assembled LM4780 circuit with a guitar and an 8 ohm speaker the transformer went up in smoke after about a minute. The first minute sounded really good, btw. The x-former was rated at +/- 24V (48V with CT) @ .63 amps. After that was rectified, it was about 38.2VDC without a load, on a snubberized PS kit board. The specs on the 4780 said 80V max, so I tried it with an 8 ohm speaker load and the transformer overheated. Quickly I hit my handy power strip switch and I think everything is still ok.
The question: Will I need 2 or more amps at 38V? Has anyone had marvelous success feeding a 4780 (chipamp) board? And at what current/voltage did you supply it? Also, I have two 8 ohm speakers that I could either make into 16 (series) or 4 (parallel). What would be the best scenario? -ASC |
#2 |
0.63A?
I think you want about 10A |
#3 |
To be more precise, and to be safe, you want at least as much rated current capacity as the electronics are rated to produce. If your amplifier datasheet says it can put out 3 amps, get at least a 3A rated transformer.
If you get one that is rated for at least 2-3 times the current (e.g., 10 amperes), then the voltage will tend to droop much less and you will have good things like "less clipping" and "punchy bass" and "non-smoking transformers" etc.
Jesus loves you. |
| PPI resistor smoked | markw78 | Car Audio | 22 | 16th July 2009 07:39 PM |
| Transformer smoked | Aidan135711 | Parts | 3 | 1st August 2008 09:34 PM |
| Smoked Yamaha M-50 | eb5agv | Solid State | 3 | 10th May 2008 08:07 PM |
| Smoked resistors | darkfenriz | Parts | 4 | 30th April 2006 07:09 PM |
| Page generated in 0.08200 seconds (71.79% PHP - 28.21% MySQL) with 10 queries |
