| Chip Amps Amplifiers based on integrated circuits |
I have just finished my first LM3886 dual Mono Amp. It is based on the BrianGT PCB. For the PSU I use a 160 VA toroid transformer (2x22VAC) with the Carlosfm inspired snubberized design. Since I use a 9-pin Sub-D for the interconnection I have the option to power each channel with a separate PSU. There are also two 1800uF caps for each channel near the chips power pins.
(I am not so happy with the Sub-D connector. The contacts are rated with a maximum of 3A/pin. Maybe I will use the high-current-version for my next design.) The enclosure is simply built with two heat-sinks (Fischer SK85 -160x40x50(mm)) and 4 aluminium plates The overall dimension are 50x180x160 (mm) (H-W-D) without the knob, connectors and spikes. I think that the heat-sinks are a bit oversized for this design. For the connectors (Speaker and RCAs) I,ve used types that I’ve found in the nearest store. Cardas or WBTs are not really an option for my budget. The last think I have finished was the knob for the volume control. It is built in massive brass wit 40 mm in dia. Now I go and search for a nice enclosure for the PSU that match to the Amp-design and will – with respect -not be a copy of the great 47 Lab design. For me the best sound impression for this Amp-design is without any cap in the signal path and the additional caps near the LM3886 power pins. Since the output offset voltage for both channels are below 30 mV I’ve removed the offset compensation cap too. Finally: Without the inspirations and experiences from all the great people in this forum I’d never started this Chip Amp project. I hope I don’t boring you if I add some pictures of my finished Amp. Thank you all. Bernd |
#2 |
sweet amp!
let's see more pics! and the insides too...
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa |
#3 |
It looks very good!
#4 |
Banned
C
#5 |
That looks fantastic. Great job!
#6 |
Here are some more pictures of my 3886 Amp:
#7 |
...more pictures
#8 |
one more picture:
#9 |
picture from the top:
#10 |
Banned
Oooohhhh... so ssssexy.
| BrianGT chipamp.com dual mono lm3886 amp | valleyman | Swap Meet | 8 | 21st October 2008 11:43 AM |
| transformer for LM3886 dual mono kit | gonzalez | Chip Amps | 16 | 11th October 2008 10:55 AM |
| Shorting Brian's LM3886 dual mono | herrdahlin | Chip Amps | 1 | 13th October 2006 09:33 AM |
| Single Mono's or Dual Mono? | Tazzy | Pass Labs | 8 | 3rd October 2002 03:03 PM |
| Dual Mono - Anti Mono Power Supplies | pmkap | Everything Else | 3 | 16th February 2002 06:10 AM |
| Page generated in 0.11154 seconds (75.48% PHP - 24.52% MySQL) with 11 queries |
