diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   GC Heat (http://www.diyaudio.com/forums/chip-amps/60737-gc-heat.html)
VoLCoM 13th July 2005 11:06 PM
GC Heat
I am running my 3875 gainclone with a 4ohm load and i have a big heat sink made out of aluminium that measures about 7.5" x 3" x 1/8" full of fins on one side and they are about 2 inches long. My two chips are on the same heatsink and when the volume is at maximum it gets pretty hot. i don't know if it's normal...it's my first gainclone :)
should i buy another heatsink??? or its completly normal.... i searched the forums and they say that running the gainclone at 20v shoudn't dissipate any heat (mines runs at 20volt AC before rectifier and 28.5V DC after )
slackman 13th July 2005 11:23 PM
What about the sound? Good and loud or not as loud as you assumed?
At full volume it's normal if it runs warm/hot but take care of some points:
- are the chips isolated? If not are they isolated mounted?
- check inputs and outputs: may the gc oscillate (capacitors with wrong values)?
Some pics would help...
Michael
VoLCoM 14th July 2005 12:03 AM
2 Attachment(s)
Michael
The sound is very good and loud
the chips are 3875TF (isolated)
and for the oscillation .... i bought a kit from Peter Daniel and installed everything that came in the kit so i guess they are the right values
But at low volume everything's alright i guess the heat is normal. and when i put a 8ohm load the temperature is even lower. i tought the 3875 couldn't handle 4ohm impedance
carlosfm 14th July 2005 12:26 AM
That heatsink is thin for the PSU voltage you are using and to drive 4 ohm speakers.
It's more indicated for convection cooling.
VoLCoM 14th July 2005 12:28 AM
ok, i'll find another heatsink....what are your suggestions??? ...that was just a heatsink i had lyin around... and decided to use it because it was the biggest i had
DcibeL 20th July 2005 08:36 PM
The heatsinks offered in this thread look like they would work great for a chipamp, as long as they are still available at $10 for 2 you really don't have a lot to lose.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
