My tiny single sided LM3886 PCB layout. :) My tiny single sided LM3886 PCB layout. :) - Page 7 - diyAudio
Old 26th May 2006, 09:42 AM   #61
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
RZBL=2.7 OHMS/ 2Watts Carbon.
CZBL =100Kpf/100 Volts polyester.
Gud Luc
SivanandBalan
Old 28th May 2006, 06:24 AM   #62
DJ Exprice is offline DJ Exprice  United States
DJ Exprice's Avatar
Send a message via AIM to DJ Exprice Send a message via MSN to DJ Exprice
Sweet Boards I made from the schematic CHECK EM OUT!
I have the Eagle LM3886 boards, the Gerber Files,
some sweet PDFs, and a parts list (be sure to read that!.
Enjoy!
Here are the Files
Old 28th May 2006, 01:38 PM   #63
frank1 is offline frank1  United Kingdom
Default PCB making
Russ, thanks very much for sharing this great design, also the method used to make PCB's.
My problem is, I want to print two or more images at a time to make a small number of boards. It would be great if I could copy and multiple images onto one page but the format is PDF so I can't do this.
Any ideas ?
Frank
Old 28th May 2006, 01:46 PM   #64
Bazukaz is offline Bazukaz  Lithuania
Bazukaz's Avatar
You can print screen the images("Prn Sc" button). This saves the current screen to clipboard.
Or , use PDF to image converter program , and then use any painting software, like Paint.
Lukas.
Old 28th May 2006, 04:50 PM   #65
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
If you use print screen you will end up with a lower resolution printed image. Best would be to use software to convert the PDF into an image format such as PNG, GIF or BMP. Do not use JPG as that will make it horrid.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 6th July 2006, 06:12 PM   #66
Voltaic is offline Voltaic  United Kingdom
Enjoy!
Here are the Files
Are these the same as the original Russ White boards, or something different? Either way, they're nicely done, I'm just curious.
cheers,
Daniel
Old 6th July 2006, 08:57 PM   #67
DJ Exprice's Avatar
The boards I made are based on Russ's Schematic. I give him full credit for the schematic. I just decided to make a more "organized and complex" board. His single sided one still better, because it's single sided All the better for Diy-ing at home (etch or single sided milling if you have a machine or are going to get one soon like me)
Old 6th July 2006, 10:56 PM   #68
ahhh ok, do you happen to have the PDF's and/or gerbers for the single sided layout? the old link from russ is broken, and I'd like to give this one a shot, I just got 4 free LM3886's in the mail today.
cheers,
Daniel
Old 6th July 2006, 11:07 PM   #69
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
Hey guys sorry for the broken link. I will see if I can find the PDFs and repost them.
Cheers!
Russ
Less pulp more juice Twisted Pear Audio.
Old 7th July 2006, 12:01 AM   #70
Excellent! cheers then mate.
My tiny single sided LM3886 PCB layout. :)Hide this!Advertise here!
lm3875 single sided pcb layout SolderN Chip Amps 18 12th August 2009 10:11 PM
pa100 pcb single sided layout lm3886 dgaxeman Chip Amps 6 24th May 2006 01:45 AM
Wanted single sided PCB layout sivan_and Chip Amps 6 26th January 2006 10:36 PM
Copyright ©1999-2017 diyAudio
