My tiny single sided LM3886 PCB layout. :)
Old 13th July 2005, 09:40 PM   #21
squadra is offline squadra  Thailand
squadra's Avatar
Originally posted by Russ White
Now with zobel. I think is it.
Please print the pcb on a 1:1 scale.
Objects might be closer than they appear
(I found out the hard way, for my own pcb it looked like there is plenty of space for big caps but there was just enough room for normal caps)
I dither, therefore I might be.
Old 13th July 2005, 10:31 PM   #22
Russ White is offline Russ White  United States
Russ White's Avatar
Send a message via Yahoo to Russ White
No worries man, I already completed the boards, everything fit fine. Pics to come later.
Less pulp more juice Twisted Pear Audio.
Old 14th July 2005, 01:47 AM   #23
Russ White's Avatar
Default Boards finished, pics
Here are the pics. Tomorrow after work I will put them in a case and try them out.
Old 14th July 2005, 01:50 AM   #24
Russ White's Avatar
These things go together really easy, nothing very hard to solder.
The size is 1.5" x 1.75"
Old 14th July 2005, 09:30 AM   #25
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Liking it. I don't think I'll bother with my single sided board attempt now
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 14th July 2005, 10:03 AM   #26
Tekko is offline Tekko
Banned
Single sided boards are so mutch easier to design. Double sided are a pain to design.
Old 14th July 2005, 11:08 AM   #27
Did it Himself
The design isn't so bad, the board production and soldering is the pain.
Old 14th July 2005, 11:41 AM   #28
Russ White's Avatar
Thanks to all for the support and advice!
I am tweaking some of the pads and spacing this morning just to make this thing a little more polished, and after that I will will post the eagle files for everyone to enjoy. Cheers!
Old 14th July 2005, 12:03 PM   #29
Did it Himself
My tip is to allow a bit more room around the zobel resistor, try not to bend the legs so close to the body. Doesn't need much more room though. You could also lose a bit of the ground plane around the backside of the chip which would allow you to bring the mute trace in a bit and the board smaller/chip closer to the heatsink/better clearance for the trace-heatsink. Do you have to bend the chip legs a bit as it is, to get it flat against the heatsink?
Old 14th July 2005, 01:19 PM   #30
VoLCoM is offline VoLCoM  Canada
If i want to make one for myself how do i do it??? is there any special program??? i know that i need a laser printer and an iron to put it on the board but theres going to have all the components printed too??(silkscreen) am i wrong? how did you print it?
My tiny single sided LM3886 PCB layout. :)Hide this!Advertise here!
lm3875 single sided pcb layout SolderN Chip Amps 18 12th August 2009 10:11 PM
pa100 pcb single sided layout lm3886 dgaxeman Chip Amps 6 24th May 2006 01:45 AM
Wanted single sided PCB layout sivan_and Chip Amps 6 26th January 2006 10:36 PM
Copyright ©1999-2017 diyAudio
