My tiny single sided LM3886 PCB layout. :) - Page 2 - diyAudio
Old 13th July 2005, 03:18 PM   #11
Russ White's Avatar
Send a message via Yahoo to Russ White
Yes, I know, but would they still not interact?
Less pulp more juice Twisted Pear Audio.
Old 13th July 2005, 03:28 PM   #12
Mr Evil is offline Mr Evil  United Kingdom
The point of a Zobel network on the amp's output is to provide a low impedance termination for high frequencies, which increases stability. A Zobel in a speaker can't do that because it's seen through the resistance+inductance of the speaker cable.
Of course you might not need a Zobel, but it can't hurt to leave room for one, just in case.
https://mrevil.asvachin.eu/
Old 13th July 2005, 04:45 PM   #13
Russ White's Avatar
Yeah, I understand they have different roles, but I thought I read somewhere that they could interact. Still, I suppose putting places for the components is a good idea, and it can't hurt as you can omit them. I will do so in the next revision.
Old 13th July 2005, 05:57 PM   #14
mateo88 is offline mateo88  United States
Does pin 5 need to be connected to V+, or can you just choose between 1 and 5?
Old 13th July 2005, 06:02 PM   #15
BrianGT is offline BrianGT  United States
diyAudio Moderator Emeritus
BrianGT's Avatar
Send a message via AIM to BrianGT
Default Re: Update
Originally posted by Russ White
OK, I tweaked the layout a little and etched the boards. I will build the amp tonight. Here is the latest layout:
The board looks good. It certainly is more tricky working with 1 layer.
Do you not need to tie pin 5 to V+? I haven't tried it without it, but I guess you could put a short circuit jumper on the chip package to tie these pins together to V+.
Best of luck with the amp,
Brian
Old 13th July 2005, 06:15 PM   #16
Russ White's Avatar
Hmmmmmm.... In the library I have pin 5 is not connected to V+! I will have to fix that.
Here we go.
Old 13th July 2005, 06:40 PM   #17
BrianGT's Avatar
Looks better. Another suggestion is to make the NC pads on the chip smaller, so that you can maximize the power traces.
Brian
Old 13th July 2005, 07:01 PM   #18
Russ White's Avatar
How is this?
Old 13th July 2005, 07:24 PM   #19
Russ White's Avatar
Now with zobel. I think is it.
Old 13th July 2005, 07:31 PM   #20
Banned
Good job
lm3875 single sided pcb layout SolderN Chip Amps 18 12th August 2009 10:11 PM
pa100 pcb single sided layout lm3886 dgaxeman Chip Amps 6 24th May 2006 01:45 AM
Wanted single sided PCB layout sivan_and Chip Amps 6 26th January 2006 10:36 PM
Copyright 1999-2017 diyAudio
