STK407-050 module alive and kicking - Page 3 - diyAudio
Old 17th July 2005, 12:53 PM   #21
Banned
im still trying to get to the bank, it would be so mutch easier if you have had a paypal account. Btw whats your adress again ? Im gonna try tomorrow. I do feel bad that it has taken this long but now i feel that i wanna get this payment sent. Im even gonna send some extra for the time gone and for the schematics.
Old 17th July 2005, 01:37 PM   #22
Franz G is offline Franz G  Switzerland
Franz G's Avatar
No, please dont do this!
BTW: I sent you my addresse again.
Proposal: back to the topic
Franz
Old 17th July 2005, 05:22 PM   #23
XELB is offline XELB  Portugal
Originally posted by Tekko
PPS: XELB, which one do you have ? [/B]
Mine is STK4152 II.
The Sanyo schematics came normally with 50x gain.
I have change the value for ~26. (100R and 2K)
A few members of this forum also reported that the chip becomes more stable.
The differences I notice were mainly in dynamics.
This could also be due to other changes, I dont use inductors, I hate the slow bass they produce and I also changed a few caps.
If you want power you must add control
Old 17th July 2005, 05:31 PM   #24
Banned
What is the inductors for ? I dident use the zobels but i put in the inductors, maybe i should bypass them and change the gain to 26 ? Tho that will make the volume so low that id need a separate preamp, no ?
Do you have any pics of your amp using the module ?
Old 17th July 2005, 06:54 PM   #25
You don't need pre Amp.
You have the volume knob for some reason
The difference is that with ~35 gain you "block" the input to have "X" dB.
With the gain of 26 you can't "block" the same amount of signal if you want to have the same output.
The 26 gain also guaranties that I will not have clipping.
Old 17th July 2005, 07:02 PM   #26
Banned
So that means ill need to turn it up about twice as mutch after the change than before ?
Old 17th July 2005, 09:20 PM   #27
The question is, do you wont an amp to impress your friends because it plays very loud with little volume or if you want an amp that impress because its detailed and accurate.
Why do you give much importance to the "volume" ?
Mine STK came with 50x gain and when the volume knob passed the 1/2 it started clipping and losing quality. I couldn't use the other 50% of the volume knob
In commercial applications high gain can impress lots of people because when they test the amp they will see that, with little percentage of volume the output its very high.
So, they think, " this amp have lots of power, I just use volume and the output was enormous "
But they forget that the chip have limitations and when you reach the limitations the sound gets rubbish.
Old 17th July 2005, 10:42 PM   #28
Banned
So the same values as you used ( 100 ohm and 2k ) should work as well with my module as your 4152 ? Did you change the cap in the gain set circuit or did you leave it ? I have 47F caps in the gain set circuit.
JBl GTS600, amplifier wanted! Dead or Alive, Alive if it can be helped:) Paradise_Ice Swap Meet 11 10th June 2013 03:02 PM
Data/pinout on STK407-250 Tekko Chip Amps 14 27th May 2012 09:26 AM
Aikido - alive and kicking butt (not mine!) cbutterworth Tubes / Valves 1 20th December 2006 02:41 AM
Stk407-710k florin01 Chip Amps 0 27th November 2006 05:44 PM
Diagram STK407-090 panterka Chip Amps 1 24th April 2006 07:24 AM
Copyright 1999-2017 diyAudio
