| Chip Amps Amplifiers based on integrated circuits |
I've build the suggested schematic on pdf file of datasheet.
But i've the following trouble... 1) Turn on my PSU +/-24V 2) All wire connected (input/output) The trouble is here... I give +5v at pin3 and for a second it seems to give the right power to the speaker and immediactly after it goes at lower volume with a little tendency to give high frequency as output... I hope to have be clear.... Some suggestions? |
#2 |
Make sure c3 is connected properly(double check the polarity) and connected to Neg rail supply not ground.
#3 |
Are the red polarity correct?
And if it's alway connected to negative it's always in stand by.... |
#4 | ||
What is the voltage of your transformer? You may have to lower the supply voltage. |
#5 | ||
![]() Quote:
#6 |
It is likely to be something simple. Lets start eliminating possible problems.
1 make sure all cap are connected properly(polarity) 2 check all ground wiring 3 measure resistance at pins(between pin and ground) 4 C1 bewteen R1 and pin 7(not R1 and ground) 5 measure at pins 5and 7 : bewteen pins 1 and 6 and bewteen 1 and the (+) of C2 |
#7 |
all checked and all seems to be ok...
TDA is NEW!
#8 |
Check resistance at pins 2 and 3
#9 |
Excuse me..
But pin 2 should be connected directly to +V and pin 3 is for play/stand by (by a 22k resistor) and when i want PLAY i make a short to +v right? |
#10 |
Dont connected any. Only check the resistance bewteen the pins,You know what the resistance should be.
I looked at the picture you posted everything seem OK. The only thing I see that maybe a fault is a possible connection bewteen pin2 and 3(look inside the square). Have you built more than one?. You make just have a bad chip. It happens. Were is the +5V for pin 3 coming from? |
| sound of TDA7296 and TDA2052 | wleediy | Chip Amps | 1 | 25th July 2008 07:59 PM |
| Is there a way bridge the TDA2052 | shon35us | Chip Amps | 3 | 30th March 2007 06:56 PM |
| TDA2052 bridged? | MaXiZ | Chip Amps | 3 | 29th June 2004 12:56 AM |
| About tda2052 | MaXiZ | Chip Amps | 2 | 7th December 2003 11:34 AM |
| Page generated in 0.18401 seconds (44.68% PHP - 55.32% MySQL) with 11 queries |
