Old 9th July 2005, 04:07 AM   #11
I'm leaning toward using the mauro Penasa version as previously suggested. Seems like a nice setup and for toppers the PCB has already been designed and tested. piece of cake.
That means I just need to design the logic portions now. :-) I just ordered a bunch of copper clad (2 and 1 sided) off ebay so PCB's will be sure to follow.
Old 9th July 2005, 04:12 AM   #12
another ideas for the backlighting would be like this....
take the face. Cut a circular hole...say 3/4" diameter. Now cut a piece of circular lucite 3/4" diameter. Now drill a hole 1/4" diameter for the shaft of the pot to fit through. Put LED's shining on the lucite and it should diffuse everything quite nicely...plus you could bring out that shaft of lucite a bit to help throw the light out a bit too.
Old 9th July 2005, 04:15 AM   #13
homer09 is offline homer09  Canada
homer09's Avatar
glad to see you like my suggestions
if your quick i think you can still tag on to this group buy and save some money on the parts:
http://www.diyaudio.com/wiki/index.p...sa+GC+Parts+GB
Most people wouldn't know good music if it came up and bit them in the ***. - Frank Zappa
Old 9th July 2005, 06:41 AM   #14
I'll just make my own PCB, I already own some of the parts, and I need to make an order to the suppliers for other things anyways.
I'm really looking forward to this and have put alot of thought into it. I think you guys will be impressed with my first gainclone.
Building plans for CT194? Mikael Abdellah Full Range 6 29th January 2008 08:38 PM
VBITNGC building & comment digi01 Chip Amps 456 17th June 2007 08:18 AM
HV supply please comment before building bembel Tubes / Valves 8 5th December 2006 10:16 AM
Building plans Kit pro30D (BG Neo8) Jeroenkv Planars & Exotics 3 9th August 2006 08:53 PM
My plans for this kit, any comment to improve!!!! siu sin man tho Tubes / Valves 14 16th February 2004 02:45 PM
Page generated in 0.13066 seconds (51.24% PHP - 48.76% MySQL) with 10 queries
