| Chip Amps Amplifiers based on integrated circuits |
#11 |
hey and can u also tell me how can i add a volume control to this amp?
i want a common volume control for both channels |
#12 |
hey i have assembled the board,
thing is i am plannin to use +/-30v 5amp trafo. so do u think it will do it? and i am not using this one to power a sub ok? i just want the amp to play on regular home cinema speakers. so the thing is i will be building a stereo amp that is total 4 lm3886. so will 5amp +/-30v be enough? i mean cuz u know the trafos. get real costly once u cross 5amps. and could u send me a simple regulated power supply schm? and about the zobel network, i chose the one that carlos has sent. http://www.diyaudio.com/forums/show...ht=zobel+bridge so i will need one zobel per chip right so 2 on one bridge ? i'll send u a pic of wut i mean. and thats it right no more mods ? |
#13 |
#14 |
sr2002, the 5amp 30V trafo will be fine, though if it's 30VAC, your pushing the limits of chip safe suply voltage. i know first hand they blow if being pushed higher than what's on the datasheet.
now, a 5A trafo is probably too low for a subamp. have you considered using two frafo's in paralell if thats cheaper than a 10amp one? the amp looks fine, thogh the zoble i see drawn looks like two resistors in series to ground, wich is offcource wrong. i presume you mean the zoble as a R-C link? Now, as for regulation, for a subamp, this is not only unneeded, but indeed introduces it's own new set of problems. so just trouble and more cast will be the resoult in this case i would say. a simple regulation design can be found on another of carlosfm's threads. this thread: LM338 regulated snubberized PSU for audio amplifiers good luck! Marius |
#15 |
hey thanks alot again,
as i told u i am not using this amp to power a sub!!!!!!!!!!! i am using it to power regular bookshelf speakers.so will i need and noise filters? i was planin to use the filter given in the attached file. what do u think? i am building a 2-channel amp based on the br100. that is to boards in parallel with the power supply thats why i asked u whether 5 amp is sufficient? so a total of 4 lm3886 are there in the circuit. and the power supply that u sent me is looks really complex. do u have anything much simple than that. wut if i use two trafos in series? and that calosfm has written somethin below "add caps to chips psu pins" what does that mean? |
#16 |
hey ,
wut do u think of this power supply? and i think i'll use 20v trafos to be on the safer side hey and wut if i connect the 2 trafos. as u said instead of one, and wut if one trafo. is like is 22v and other is 20v or something like. i mean wut if the 2 trafos are not exactly of the same voltage and amps. will that blow up the power supply |
#17 |
heres the schematic of the psu
#18 |
heloo demogorgon,
r u busy please answer my post man. |
#19 |
hey, sr2002, I just uppgraded my pc, but my motherboard didn't come with a seriel port, so i cant use my modem no longer.
(abit an8ultra) so i'm sitting at a friends place right now, but dont have the time to help you right now. I'l try to get on line tomorrow though. take care Marius |
#20 | ||||
This is the first of carlo's snubbed psu's, use the one he links to here instead. http://www.diyaudio.com/forums/showt...018#post534018 Quote:
(so try to use two identical) hope this helps you out. -Marius |
| crude, simple and powerful PP-amplifier | Mikael Abdellah | Tubes / Valves | 11 | 25th April 2008 07:02 PM |
| Powerful bass | syl | Solid State | 13 | 2nd July 2007 10:29 PM |
| Help!very Powerful Amp Needed! | hernanstafe | Solid State | 8 | 15th March 2007 01:30 AM |
| more powerful Charlize equivalent | Rafal | Class D | 8 | 20th December 2006 03:57 PM |
| Simple, powerful (100W-200W into 8ohm) amplifier schematic needed | ddog | Solid State | 14 | 23rd April 2004 04:36 AM |
| Page generated in 0.15877 seconds (73.89% PHP - 26.11% MySQL) with 11 queries |
