A few chip amp questions - Page 2 - diyAudio
Old 7th July 2005, 01:40 PM   #11
Aghead is offline Aghead  Canada
Not to disagree with Doovieman, but too much capacitance can be a problem, from a listening point of view.
e.g. for some time I was running my Rotel bx940 cd player with pair of "huge" 22000 microfarad caps, 10x the original.
It certainly made the sound more robust, punchier, and more time coherent.
BUT, switch to a more moderate size cap (6800) and the above mostly stays but the musicality of the midrange, and dynamics are much improved (probably because there is more silence when instruments stop playing)
I know that seems contradictory, how can "punchy" make less dynamic, but I think these effects are quite frequency dependent.
This is just what I hear, no idea what scoping it would show.
Old 8th July 2005, 04:27 AM   #12
lgreen is offline lgreen  United States
lgreen's Avatar
Default Re: A few chip amp questions
Originally posted by bigwill
I'm thinking of buildling a chip amp but I'm still unclear on a few things.
1. What's the difference between inverting and non-inverting? Obviously one inverts the signal, but why do people seem to prefer wiring up their chip amps so they invert? What're the sonic differences?
Any info would be much appreciated
If you look at the inverting and noninverting circuits you will see that the inverting has a much lower input impedance, which is why a buffer prior to the input is preferred for inverting...I suppose.
Old 13th July 2005, 10:30 AM   #13
Default big caps
Hi, ito big capacitance...
My experience so far has been that big caps (5 pll 10000uf for six channel active) with normal 2200uf(mid/woof) and 1000uf (tweets) near/on chips sound fine, add 150nf MKT's in pll on chips and treble gets smoother, but also softer - wasn't sure if real improvement or just softer, but pleasant sound.
I replaced 150nf's with MKP's (On tweeter amp I used 220nf pll with 22nf just because I had a limited amount of 150nf - but I think 100nf/150nf will be fine) and definite improvement in treble... I can't really say if it was the change in values or the change in dielectric...
Cymbals etc really better - used to be a bit thrashy or just "tsk tsk tsk" when loud or fast (compared to before MKT's didn't listen long enough with MKT's to really evaluate thoroughly)- This didn't really bother untill I listened to much more costly tweets. Now treble is better defined and ringining of cymbals better reproduced even really high. In my system I can now completely hear what is being done with which cymbal - where and how it gets struck, percussive instruments lower down freq. scale also sound better defined probably due to better treble as drums get struck. Violin is better, massed strings I think me tweet is still not up to that sounding real... Oh yes, this is with a ZAR250 tweet (about 20 euro/pounds?) All amps are NI... standard Natsemi diagram without mute. Hitano EXR caps for 1000uf/2200uf
Replaced all MKT's with MKP's am not sure if midrange or bass improved - I think the improved treble just makes what seems to be better midrange - most midrange noises is sandwiched... open or closed with treble.
Cheers
Andre
Brian GT chip amp build Questions guycom Chip Amps 5 15th September 2008 10:02 AM
Some Quad els57 questions! - Novice Questions! Fanuc Planars & Exotics 13 5th December 2007 09:26 AM
A few questions about Building a LM3886 Chip amp??? Minion Chip Amps 21 13th October 2006 08:01 PM
HCCA X-Over chip questions jesserettele Chip Amps 0 5th April 2005 06:37 AM
general chip questions Ropie Chip Amps 2 11th July 2004 09:05 AM
Copyright 1999-2017 diyAudio
